hello, I checked the flight distance in the px4 flight review.
Can I check the elapsed distance according to the time [timestamp] with the csv file?
Distance could not be checked in the csv file obtained through pyulog.
I need your help. Thank you.
Let me ping @bkueng. He knows more about pyulog.
It’s calculated. This is how flight review does it: flight_review/plotted_tables.py at d3e01a2890bee0620442df3e8e41f15b17a4a5bf · PX4/flight_review · GitHub
That’s exactly what I wanted. Thank you so much!
How accurate is the estimated distance in a log file?
Got the code to get the total distance from the section @bkueng told me. After that, the pyulog code is used after applying it after some modifications.
There is no comparison target for accuracy, so it will be difficult to answer.
