I’m trying to create a program to generate .tlog file using pymavlink.
Here is the program which I’m currently running:
import time
from pymavlink import mavutil
connection_string = 'tcp:127.0.0.1:14550'
master = mavutil.mavlink_connection(connection_string)
tlog_file_path = 'telemetry_log.tlog'
tlog = mavutil.mavlogfile(tlog_file_path, write=True)
try:
while True:
msg = master.recv_match()
if not msg:
continue
buf = msg.get_msgbuf()
tlog.write(buf)
print(msg)
except KeyboardInterrupt:
tlog.close()
print("\nTelemetry logging stopped. TLog file saved at:", tlog_file_path)
But I’m not able to read or run the generated .tlog file by this code properly by using pymavlink or mission planner.
Can anyone help me.
