Hello everyone, how to connect to the SITL jmavsim using qgc android app? From laptop it connected automatically, but in android it shows nothing. I added IP of pc and port 4560. It does not connect. I also tried it with udp port 14450, with IP of phone, but nothing helps. How to add data correctly?
Please try this:
You need to use broadcast: https://dev.px4.io/master/en/simulation/#enable-mavbroadcast
Or set the IP of your phone as explained here: https://dev.px4.io/master/en/simulation/#modify-configuration-for-external-broadcasting
