How to build Firmware for fmu-v1 using Qt creator in ubuntu?
Hi,guys
I build Firmware follow this Tutorials http://dev.px4.io/starting-building.html.
It work well by selecting ‘custom executable’ in the run target configuration and entering ‘make’ as executable and ‘upload’ as argument.
But i want to build pxfmu-v1_default .It can’n work by selecting ‘pxfmu-v1_default’ as argument.
@wswday
did you find a solution ? I am confronted to the same problem…
I can build the fmu-v1_default code in a terminal but I would rather build it in Qt environment.
Note that there’s a line in CMakeLists.txt:
set(CONFIG "nuttx_px4fmu-v2_default" CACHE STRING "desired configuration")
Try changing that line to set a v1 build instead.
