Hi everyone, I have a problem about firmware building V1.4.1 run on px4console. After clone the code form github and run make px4fmu-v2_default, all message shown as follows->
$ make px4fmu-v2_default
– nuttx-px4fmu-v2-default
– Found assembler: E:/px4/toolchain/bin/arm-none-eabi-gcc.exe
– Found PythonInterp: E:/px4/Python27/python.exe (found version “2.7.3”)
CMake Warning (dev) at cmake/common/px4_base.cmake:279 (message):
STACK deprecated, USE STACK_MAIN instead!!!
src/systemcmds/motor_ramp/CMakeLists.txt:33 (px4_add_module)
This warning is for project developers. Use -Wno-dev to suppress it.
– Using C++03
– Release build type: RelWithDebInfo
– Adding UAVCAN STM32 platform driver
– GIT_TAG = v1.4.0rc1
– Configuring done
– Generating done
– Build files have been written to: E:/px4/v1.4.1_release/Firmware/build_px4fmu
-v2_default
PX4 CONFIG: px4fmu-v2_default
Scanning dependencies of target git_genmsg
Scanning dependencies of target git_gencppScanning dependencies of target git_ua
vcanScanning dependencies of target git_nuttx
[ 0%] Generating git_init_Tools_genmsg.stamp
[ 0%] Generating git_init_src_modules_uavcan_libuavcan.stamp
[ 0%] Generating git_init_NuttX.stamp
[ 0%] Generating git_init_Tools_gencpp.stamp
[ 0%] Built target git_genmsg
[ 0%] Built target git_uavcan
[ 0%] Built target git_nuttx
[ 0%] Built target git_gencpp
Scanning dependencies of target git_matrix
Scanning dependencies of target git_mavlink
Scanning dependencies of target mixer_gen
Scanning dependencies of target libuavcan_dsdlc
[ 1%] Generating git_init_src_lib_matrix.stamp
[ 1%] Generating git_init_mavlink_include_mavlink_v1.0.stamp
[ 1%] Generating mixer_multirotor.generated.h
[ 1%] Running dsdl compiler
[ 1%] Built target git_matrix
[ 1%] Built target git_mavlink
[ 1%] Built target mixer_gen
Scanning dependencies of target git_ecl
Scanning dependencies of target xml_gen
Scanning dependencies of target nuttx_export_px4fmu-v2
[ 1%] Generating git_init_src_lib_ecl.stamp
[ 1%] Building NuttX for px4fmu-v2
rsync: Failed to dup/close: The descriptor is a file, not a socket (108)
rsync error: error in IPC code (code 14) at /usr/src/rsync/rsync-3.0.8/pipe.c(14
7) [Receiver=3.0.8]
[ 1%] Built target git_ecl
[ 1%] Generating parameters.xml
Scanning dependencies of target nuttx_export_px4io-v2
rsync: read error: Connection reset by peer (104)
rsync error: error in IPC code (code 14) at /usr/src/rsync/rsync-3.0.8/io.c(760)
[sender=3.0.8]
[ 1%] Building NuttX for px4io-v2
7) [Receiver=3.0.8]
make[3]: *** [px4fmu-v2.export] Error 14
make[2]: *** [CMakeFiles/nuttx_export_px4fmu-v2.dir/all] Error 2
make[2]: *** Waiting for unfinished jobs…
[sender=3.0.8]
[ 2%] Generating airframes.xml
make[3]: *** [px4io-v2.export] Error 14
make[2]: *** [src/modules/px4iofirmware/CMakeFiles/nuttx_export_px4io-v2.dir/all
] Error 2
[ 2%] Built target libuavcan_dsdlc
[ 2%] Built target xml_gen
make[1]: *** [all] Error 2
make: *** [px4fmu-v2_default] Error 2
The previous firnware such as Version 1.4.0 I can run and upload perfectly without any problem. Please guilde me how to fix it.
Thank you so much.
