Hi yigitcan, thank you for the careful read. Here is the per mutation chain you suggested, 18 rows, one per surviving mutation. Each row has a number, so the two mutations at line 429 are now #5 and #6. The category is my own classification, not a measurement. The observation point is the earliest place where original and mutant differ, taken from my probe output.
#1, line 89, 0 to 1: return value of mavlink_sign_packet. Category 3 Semantic decode.
#2, line 241, >= to >: sanitizer (ASan abort, WRITE of size 4, mavlink_helpers.h:252). Category 1 Runtime / memory integrity.
#3, line 418, 2 to 3: none found. Equivalent candidate, not proven.
#4, line 424, && to or: bytes sent (checksum over sent buffer). Category 4 Outbound representation.
#5, line 429, > to >=: bytes sent and parse error flag. Category 2 Protocol acceptance / parser state.
#6, line 429, or to &&: sanitizer (ASan abort, READ of size 1, checksum.h:70). Category 1 Runtime / memory integrity.
#7, line 441, 255 to 256: bytes sent (count). Category 4 Outbound representation.
#8, line 591, 1 to 2: none found. Equivalent candidate, not proven.
#9, line 596, > to >=: none found. Equivalent candidate, not proven.
#10, line 673, >= to >: return value of mavlink_msg_get_target_sysid. Category 3 Semantic decode.
#11, line 826, 24 to 25: decoded field (sysid). Category 3 Semantic decode.
#12, line 847, or to &&: frame accepted or not, needs build flag MAVLINK_CHECK_MESSAGE_LENGTH. Category 2 Protocol acceptance / parser state.
#13, line 893, 8 to 9: decoded field (target id). Category 3 Semantic decode.
#14, line 907, 0 to 1: frame accepted or rejected (parse error flag). Category 2 Protocol acceptance / parser state.
#15, line 946, 0 to 1: decoded payload content (zero fill). Category 3 Semantic decode.
#16, line 1036, != to ==: parser state, only visible through a running length sum I added to my own harness. Category 2 Protocol acceptance / parser state.
#17, line 1049, == to !=: checksum field of the rejected frame. Category 2 Protocol acceptance / parser state.
#18, line 1058, 8 to 9: checksum field of the rejected frame. Category 2 Protocol acceptance / parser state.
On your other points: all 18 survived my existing fuzz harness, and every divergence above was shown only by a targeted follow up probe, so none of them counts as detected by the existing suite. Rows 12 and 16 are configuration dependent, so I will add a build configuration column for all rows. The 21 versus 22 difference is still unexplained. I have four full runs, two at 21 and two at 22, and I have not yet identified which mutation flips. I will do a deterministic replay and report back here, and I will not treat 22 of 40 as a stable number until then.
