Hi Yigitcan,
a correction to my last post, plus a new measurement.
In my last post I wrote that the 15 new tests were measured with gcc. That was only the default of my scripts. The exact compiler version was not recorded in the first runs, so I cannot state it for them.
To close this, I repeated the 15 mutations today (13 October 2026) and logged the version this time.
Compiler: gcc (Ubuntu 13.3.0-6ubuntu2~24.04.1) 13.3.0, Ubuntu 24.04 container
Flags: -Wall -Werror -O0 -Wno-address-of-packed-member -Wno-unused-function (two mutation builds also use -Wno-parentheses, one also -DMAVLINK_CHECK_MESSAGE_LENGTH)
Sanitizer: no
Runs: 3 on the original header, 3 per mutant
Result: original green in 3 of 3 runs and mutant red in 3 of 3 runs for all 15, the same as in the first measurement. One note on the environment: the Python package lxml is missing in the container now, so the generator skipped the XML validation. The test results are not affected, but the setup is not identical to the first run.
These 15 mutations are 15 of the 18 survivors in the 40 mutation measurement, so they are not part of the 22 detected ones. Compiler and flags of the 22 are in my previous post.
I will link the per mutation table (line, operator change, trigger input, assertion, run counts) once it is final.
Best regards
Yannik
Hi Yannik,
Thank you for the correction and for repeating the measurements with the compiler version explicitly recorded.
This is a good example of strengthening reproducibility without retroactively changing the original results.
The new 13 October runs provide a clearly identified measurement environment, and the 3/3 original-pass versus 3/3 mutant-fail outcomes across all 15 cases are useful evidence that the targeted assertions distinguish those mutations under the recorded configuration.
I also appreciate your transparency about the missing lxml dependency and the skipped XML validation.
I would preserve that difference in the evidence record rather than treating the new environment as identical to the earlier one. If the generated headers used by the tests can be identified by their exact source revisions or hashes, that would help establish the scope of the comparison.
The separation between the original 40/22/18 mutation measurement and the subsequent 15 targeted regression tests remains clear.
I look forward to reviewing the per-mutation table when it is ready.
Best regards,
Yiğitcan Öztürk
PAMILANGA LTD
Hi Yiğitcan,
thanks for the careful read. I agree that the 13 October environment should stay a separate record and not be merged with the earlier one. In the manifest it will be its own set of rows, with the compiler version and the missing lxml dependency (XML validation skipped) noted per row.
On the generated headers: good point. For the 15 tests I have not yet recorded the exact source revision or hashes of the headers they were built against. I will check whether they can be identified and add that as a column. If they cannot be identified for the earlier run, I will say so in the table instead of filling the gap.
The per mutation table follows once that column is in.
Best regards,
Yannik
