Help with uORB and the mc_att_control_main.cpp
Hi everybody i have some doubts in the code mc_att_control_main.cpp, first in the code there is a section in which the author “declares” the subscription of many topics as you can see in the next image
After that in the constructor code there a -1, 1 or 0 in parenthesis, as you can see in the next figure
Do you know the meaning of that, please help me, i’m really new in this kind of things. Thanks
The subscription variables are file descriptors for uOrb topics (integers), which are marked as invalid in the constructor initializer list by setting them -1.
They are then initialized here:
_gyro_count and _selected_gyro are variables used to choose which gyro topic to use. There may be multiple gyros on a flight controller, each being published on their own sensor_gyro uOrb topic.
Note that int _sensor_gyro_sub[MAX_GYRO_COUNT] is an array of uOrb subscription handles.
_selected_gyro is used to get the data from the appropriate topic here:
Hope that helps.
Thanks, it has been helpful. Thanks
