Help with a PX4 - Firmware and Flash software
I have, what I believe is a PX4 v1, When I look at the board, QGC states the following. PX4 FMU V2, Version: 5, Board ID: 255, Flash size: 2080768 .
The board appears to be wiped.
I would like to revive it if possible, but I not sure there is a current boot-loader available and any firmware.
There is no such thing as a PX4 v1.
You probably mean the PX4FMU but that looks different, so I’m not sure :man_shrugging:.
Hello Julan, I mentioned the version QGC displayed “PX4 FMU V2”
if QGC is recognizing the device, then use it to flash the firmware, follow the instructions on our docs here
Thank, I will look into using the Devel Build Master setup. I did not try that.
