I have had problems in the flight of a fixed wing with compass and external gps and AP Pixhawk,. During the mission in Auto the drone suddenly begins to fly in an uncontrolled way I am assuming that it is a “toiletbowling”. This is new, I had done many flying missions and had no problems. I made a change from GPS + Compass from 3Drobotic to a more modern GPS + Compass and changed its position, more removed from interference and made a magnetic declination adjustment. Fortunately the drone has recovered and enters RTH
RESULTADO DEL AUTO ANÁLISIS DE LOGS VUELO ALVARADO VERACRUZ
Log File C:\Users\Augusto\AppData\Local\Temp\tmp1C6C.tmp.log
Size (kb) 77242.0810546875
No of lines 1106720
Duration 0:25:46
Vehicletype ArduPlane
Firmware Version V3.6.0
Firmware Hash f8e0e91c
Hardware Type
Free Mem 0
Skipped Lines 0
Test: Autotune = NA -
Test: Brownout = GOOD -
Test: Compass = FAIL - Large change in mag_field (85.95%)
Max mag field length (594.13) > recommended (550.00)
Test: Dupe Log Data = GOOD -
Test: Empty = GOOD -
Test: Event/Failsafe = GOOD -
Test: GPS = GOOD -
Test: IMU Mismatch = FAIL - Check vibration or accelerometer calibration. (Mismatch: 2.23, WARN: 0.75, FAIL: 1.50)
Test: Motor Balance = NA -
Test: NaNs = GOOD -
Test: OpticalFlow = FAIL - FAIL: no optical flow data
Test: Parameters = GOOD -
Test: PM = NA -
Test: Pitch/Roll = NA -
Test: Thrust = NA -
Test: VCC = WARN - VCC min/max diff 0.320655v, should be <0.3v
How do you recommend correcting these errors?
I attach the flight log
https://drive.google.com/file/d/1W5wH5DvX_JmsVmAroaUUnQwO2OtQIpCq/view?usp=sharing
