this is my first time posting, so I apologize if I’m doing something wrong. I’m currently doing a project where we’re using this vtol (https://www.foxtechfpv.com/foxtech-loong-2160-vtol-mapping-package.html). Regarding the airframe, I assume I should choose the Generic AAVVT v-tail plane airframe with Quad VTOL. Is this the right choise? And if it is, what is the specific output? On the website it does’t specify, it just says “Maintainer: Sander Smeets sander@droneslab.com”.
Thank you.
I am not sure if this is %100 correct but this is what I found when I looked in the code.
Generic AAVVT v-tail plane with Quad VTOL airframe uses quad_x main and vtol_AAVVT aux mixers.
So outputs should be something like:
- MAIN1: motor 1
- MAIN2: motor 2
- MAIN3: motor 3
- MAIN4: motor 4
- AUX1: Aileron 1
- AUX2: Aileron 2
- AUX3: V-Tail 1
- AUX4: V-Tail 2
- AUX5: Throttle
