My use case involves tethering drones together, I am modifying the world with drone models, eventually adding multiple drones and tethering them to common load.
For now, I added a single x500 model to default.sdf and launched SITL with this model attached. I included the following lines at the end of default.sdf:
<include>
<uri>x500</uri>
<name>x500_1</name>
<pose>1 0 0 0 0 0</pose>
</include>
Then, I launched SITL using the command:
PX4_SYS_AUTOSTART=4001 PX4_GZ_MODEL_NAME=x500_1 build/px4_sitl_default/bin/px4 -i 0
However, I am noticing significant height drift. While the drone doesn’t continuously ascend, there are substantial deviations around the commanded altitude of 2.5m after executing commander takeoff.
I verified the pose data used by the fake GPS and magnetometer, and my model’s link (x500) is present. The sensors appear to be correctly retrieving pose data, which I confirmed using the command:
gz topic -e -t /world/default/pose/info | grep -A 5 "x500"
(as the poseinfoCallback function in GZBridge.cpp uses this topic to extract position groundtruth for the given model)
This drift is not being observed when I launch SITL with default world (without any changes) using the standard way: make px4_sitl gz_x500
Any help is appreciated!
Thank you
