GPS Position via MAVLink message
Hello! Been using the forums for a while to build some hobby projects, and I’ve been doing some tests with MAV messages and PyMAVLink.
I have started work on a project where I would like to use a companion computer or another data source to provide my own GPS messages to the flight controller, but first ideally I would like to test with SITL.
Using Ardupilot I can set GPS type 14 and send my own mav messages which contain a reliable position estimate, is there something similar for PX4? For example could I mock a generic NMEA gps device somehow and send messages that way? I tried the USE_HILGPS flag but the messages are never registered, so i must be doing something wrong. Is there a better way to do this? Is it possible to make a software based serial connection? Or an easier way? Or will i be forced to pass a position estimate to a ‘vision’ based estimator topic? Ive found some old posts with similar issues but none were resolved. TIA!
There isn’t, and it’s pretty frustrating. I’ve tried every way to send MAVLink messages (GPS_INPUT or HIL_GPS), and they don’t directly publish to sensor_gps. There are a lot of hidden gates, and the only real way to understand them is to dig into the source - which I’ll do when I have the time. Even trying to reason through the code with AI ended up going in circles.
If you ask about it on the forum, the response is usually, “what’s your use case?” PilotPi? Companion module? HIL? There are multiple paths and edge cases, which makes it more complicated than it should be. I understand why it evolved that way, but it’s still more opaque than expected.
I was able to solve this by running codex on the source tree and using the intent:
I’m running PX4 on a PilotPi (POSIX target) and trying to inject GPS using only a companion computer. The companion sends valid MAVLink HIL_GPS (previously GPS_INPUT) messages at 1 Hz over UDP (udpout:127.0.0.1:14556). MAVLink is in Onboard mode, MAV_PROTO_VER=2, MAV_USEHILGPS=1, fix_type ≥ 3, non-zero lat/lon, satellites > 0, and mavlink status confirms the messages are received with no loss. However, listener sensor_gps never publishes, vehicle_gps_position stays zero, and EKF2 does not fuse GNSS. No physical GPS is connected — the goal is to use only the companion computer as the GPS source via MAVLink. Please review the PilotPi configuration (PX4-Autopilot/pilotpi_mc.config) and PX4 POSIX build path (PX4-Autopilot) to determine why received HIL_GPS / GPS_INPUT messages are not resulting in sensor_gps publication. Create a python script to inject and send the mavlink messages to the PX4 mavlink listener.
The key issue was that PX4 receives the MAVLink packets, but only accepts HIL_GPS for publication to sensor_gps when sender sysid matches the PX4 MAV_SYS_ID (unless full HIL mode is enabled). Once I matched source_system to param MAV_SYS_ID (I’m using 1) sensor_gps and vehicle_gps_position started publishing and EKF2 fused GNSS. Before fixing source_system, MAVLink status showed packets received, but sensor_gps never published.
What I set in PX4 config:
param set MAV_USEHILGPS 1
param set MAV_PROTO_VER 2
param set SYS_HAS_GPS 1
param set EKF2_GPS_CTRL 1
mavlink start -x -u 14556 -r 2000000 -m onboard
Note HIL_GPS works here, GPS_INPUT was not handled in build and no external GPS driver is started.
This script below should do it, run using:
# mock
python3 hil_gps_mavlink.py --mavlink udpout:127.0.0.1:14556 --source-system 1 --source-component 190 --mock --debug
# real
python3 hil_gps_mavlink.py --mavlink udpout:127.0.0.1:14556 --source-system 1 --source-component 190 --serial /dev/ttyUSB0 --baud 115200 --rate-hz 5 --debug
And verify onboard that the MAV_SYS_ID is what your sending in –source-system, the value “1”.
param show MAV_SYS_ID
# => x   MAV_SYS_ID [474,1028] : 1
listener sensor_gps
listener vehicle_gps_position
hil_gps_mavlink.py:
#!/usr/bin/env python3
hil_gps_mavlink.py
Send MAVLink HIL_GPS to PX4 from either:
1) NMEA GGA over serial, or
2) Internal mock trajectory.
No NTRIP/RTCM functionality is included.
import os
import time
import argparse
import math
import serial
from pymavlink import mavutil
os.environ["MAVLINK20"] = "1"
def parse_latlon(field, hemi):
    if not field:
        return None
    deg_len = 2 if hemi in ("N", "S") else 3
    deg = float(field[:deg_len])
    minutes = float(field[deg_len:])
    value = deg + minutes / 60.0
    if hemi in ("S", "W"):
        value = -value
    return value
def send_hil_gps(mav, lat, lon, alt, fix_type, sats, hdop, debug=False):
    time_usec = int(time.time() * 1e6)
    mav.mav.hil_gps_send(
        time_usec,                 # time_usec
        fix_type,                  # fix_type
        int(lat * 1e7),            # lat
        int(lon * 1e7),            # lon
        int(alt * 1000),           # alt (mm)
        int(hdop * 100),           # eph (cm)
        int(hdop * 100),           # epv (cm)
        0,                         # vel (cm/s)
        0,                         # vn
        0,                         # ve
        0,                         # vd
        0,                         # cog
        sats,                      # satellites_visible
        0,                         # id
        0                          # yaw
    if debug:
        print(
            f"[HIL_GPS] fix={fix_type} sats={sats} "
            f"lat={lat:.7f} lon={lon:.7f} alt={alt:.2f}"
def main():
    parser = argparse.ArgumentParser()
    parser.add_argument("--mavlink", default="udpout:127.0.0.1:14556")
    parser.add_argument("--source-system", type=int, default=1,
                        help="Must match PX4 MAV_SYS_ID for HIL_GPS acceptance outside HIL mode.")
    parser.add_argument("--source-component", type=int, default=190)
    parser.add_argument("--serial", default="/dev/ttyUSB0")
    parser.add_argument("--baud", type=int, default=115200)
    parser.add_argument("--rate-hz", type=float, default=1.0,
                        help="Max HIL_GPS send rate in NMEA mode.")
    parser.add_argument("--mock", action="store_true")
    parser.add_argument("--mock-lat", type=float, default=37.7825)
    parser.add_argument("--mock-lon", type=float, default=-122.4662)
    parser.add_argument("--mock-alt", type=float, default=60.0)
    parser.add_argument("--mock-speed", type=float, default=0.5,
                        help="Meters/sec eastward drift in mock mode.")
    parser.add_argument("--debug", action="store_true")
    args = parser.parse_args()
    print("[INFO] Connecting MAVLink:", args.mavlink)
    mav = mavutil.mavlink_connection(
        args.mavlink,
        source_system=args.source_system,
        source_component=args.source_component,
        dialect="common",
        autoreconnect=True,
        force_connected=True,
    mav.mavlink20 = True
    print("[INFO] MAVLink ready")
    if args.mock:
        print("[INFO] MOCK mode enabled")
        lat = args.mock_lat
        lon = args.mock_lon
        alt = args.mock_alt
        meters_per_deg_lon = 111320 * math.cos(math.radians(lat))
        period_s = max(0.05, 1.0 / max(0.1, args.rate_hz))
        while True:
            lon += args.mock_speed * period_s / meters_per_deg_lon
            send_hil_gps(
                mav,
                lat,
                lon,
                alt,
                fix_type=3,
                sats=12,
                hdop=0.8,
                debug=args.debug,
            time.sleep(period_s)
    print("[INFO] NMEA serial mode:", args.serial)
    ser = serial.Serial(args.serial, args.baud, timeout=1)
    min_interval = 1.0 / max(0.1, args.rate_hz)
    last_send = 0.0
    while True:
        try:
            line = ser.readline().decode(errors="ignore").strip()
            if not line.startswith("$") or "GGA" not in line:
                continue
            parts = line.split(",")
            if len(parts) < 10:
                continue
            lat = parse_latlon(parts[2], parts[3])
            lon = parse_latlon(parts[4], parts[5])
            fix_quality = int(parts[6]) if parts[6] else 0
            sats = int(parts[7]) if parts[7] else 0
            hdop = float(parts[8]) if parts[8] else 1.5
            alt = float(parts[9]) if parts[9] else 0.0
            if lat is None or lon is None:
                continue
            if fix_quality == 0:
                fix_type = 0
            elif fix_quality == 1:
                fix_type = 3
            elif fix_quality == 2:
                fix_type = 4
            elif fix_quality == 4:
                fix_type = 5
            elif fix_quality == 5:
                fix_type = 6
            else:
                fix_type = 3
            now = time.time()
            if now - last_send < min_interval:
                continue
            last_send = now
            send_hil_gps(
                mav,
                lat,
                lon,
                alt,
                fix_type,
                sats,
                hdop,
                args.debug,
        except Exception as exc:
            print("[ERROR]", exc)
            time.sleep(1)
if __name__ == "__main__":
    main()
