Hey there, I am simply trying to modify the rover model for SITL purposes, but I’m running into an issue that doesn’t make sense to me. I have modified the code and included the mavlink and sensor plugins, but when I run ‘make px4_sitl gazebo_rover’, I’m getting the following error:
[0/4] Performing build step for 'sitl_gazebo'
ninja: no work to do.
[3/4] cd /home/cde01/Documents/PX4/Gazebo_Firmware_Test/Firmware/build/px4_sitl_default/tmp && /home...irmware_Test/Firmware /home/cde01/Documents/PX4/Gazebo_Firmware_Test/Firmware/build/px4_sitl_default
SITL ARGS
sitl_bin: /home/cde01/Documents/PX4/Gazebo_Firmware_Test/Firmware/build/px4_sitl_default/bin/px4
debugger: none
program: gazebo
model: rover
src_path: /home/cde01/Documents/PX4/Gazebo_Firmware_Test/Firmware
build_path: /home/cde01/Documents/PX4/Gazebo_Firmware_Test/Firmware/build/px4_sitl_default
GAZEBO_PLUGIN_PATH :/home/cde01/Documents/PX4/Gazebo_Firmware_Test/Firmware/build/px4_sitl_default/build_gazebo
GAZEBO_MODEL_PATH :/home/cde01/Documents/PX4/Gazebo_Firmware_Test/Firmware/Tools/sitl_gazebo/models
LD_LIBRARY_PATH /home/cde01/catkin_ws/devel/lib:/opt/ros/melodic/lib:/home/cde01/Documents/PX4/Gazebo_Firmware_Test/Firmware/build/px4_sitl_default/build_gazebo
gzserver: /usr/include/boost/smart_ptr/shared_ptr.hpp:734: typename boost::detail::sp_member_access<T>::type boost::shared_ptr<T>::operator->() const [with T = gazebo::event::Connection; typename boost::detail::sp_member_access<T>::type = gazebo::event::Connection*]: Assertion `px != 0' failed.
/home/cde01/Documents/PX4/Gazebo_Firmware_Test/Firmware/Tools/sitl_run.sh: line 97: 16125 Aborted (core dumped) gzserver "${src_path}/Tools/sitl_gazebo/worlds/${model}.world"
SITL COMMAND: "/home/cde01/Documents/PX4/Gazebo_Firmware_Test/Firmware/build/px4_sitl_default/bin/px4" "/home/cde01/Documents/PX4/Gazebo_Firmware_Test/Firmware"/ROMFS/px4fmu_common -s etc/init.d-posix/rcS -t "/home/cde01/Documents/PX4/Gazebo_Firmware_Test/Firmware"/test_data
INFO [px4] Creating symlink /home/cde01/Documents/PX4/Gazebo_Firmware_Test/Firmware/ROMFS/px4fmu_common -> /home/cde01/Documents/PX4/Gazebo_Firmware_Test/Firmware/build/px4_sitl_default/tmp/rootfs/etc
Here is my rover.sdf model:
<?xml version='1.0'?>
<sdf version='1.5'>
<model name="rover">
<static>false</static>
<link name='chassis'>
<inertial>
<mass>15</mass>
<inertia>
<ixx>3</ixx>
<ixy>0.0</ixy>
<iyy>7</iyy>
<ixz>0.0</ixz>
<iyz>0.0</iyz>
<izz>7</izz>
</inertia>
<pose>0 0 0 0 0 0</pose>
</inertial>
<pose>0 0 .1 0 0 0</pose>
<collision name='chassis_collision'>
<geometry>
<box>
<size>.5 .3 .1</size>
</box>
</geometry>
</collision>
<visual name='chassis_visual'>
<geometry>
<box>
</box>
</geometry>
</visual>
<collision name='front_caster_collision'>
<pose>0.2 0 -.05 0 0 0</pose>
<geometry>
<sphere>
<radius>.05</radius>
</sphere>
</geometry>
<surface>
<friction>
<ode>
<mu>0</mu>
<mu2>0</mu2>
<slip1>1.0</slip1>
<slip2>1.0</slip2>
</ode>
</friction>
</surface>
</collision>
<visual name='front_caster_visual'>
<geometry>
<sphere>
</sphere>
</geometry>
</visual>
<collision name='back_caster_collision'>
<pose>-0.2 0 -.05 0 0 0</pose>
<geometry>
<sphere>
</sphere>
</geometry>
<surface>
<friction>
<ode>
<mu>0</mu>
<mu2>0</mu2>
<slip1>1.0</slip1>
<slip2>1.0</slip2>
</ode>
</friction>
</surface>
</collision>
<visual name='back_caster_visual'>
<geometry>
<sphere>
</sphere>
</geometry>
</visual>
</link>
<link name="right_wheel">
<pose>0 -0.18 .1 0 1.5707 1.5707</pose>
<inertial>
<mass>.5</mass>
<inertia>
<ixx>0.05</ixx>
<ixy>0.0</ixy>
<iyy>0.05</iyy>
<ixz>0.0</ixz>
<iyz>0.0</iyz>
<izz>0.1</izz>
</inertia>
</inertial>
<collision name="right_wheel_collision">
<geometry>
<cylinder>
<radius>.1</radius>
<length>.05</length>
</cylinder>
</geometry>
<max_contacts>1</max_contacts>
<surface>
<friction>
<ode>
<mu>1</mu>
<mu2>1</mu2>
<fdir1>0 0 1</fdir1>
<slip1>0</slip1>
<slip2>0</slip2>
</ode>
</friction>
<contact>
<ode>
<min_depth>0.005</min_depth>
<kp>1e8</kp>
</ode>
</contact>
</surface>
</collision>
<visual name="right_wheel_visual">
<geometry>
<cylinder>
<radius>.1</radius>
</cylinder>
</geometry>
<material>
<script>
<uri>model://polaris_ranger_xp900/materials/scripts</uri>
<uri>model://polaris_ranger_xp900/materials/textures</uri>
<name>PolarisXP900/Diffuse</name>
</script>
</material>
</visual>
</link>
<link name="left_wheel">
<pose>0 0.18 .1 0 1.5707 1.5707</pose>
<inertial>
<mass>.5</mass>
<inertia>
<ixx>0.05</ixx>
<ixy>0.0</ixy>
<iyy>0.05</iyy>
<ixz>0.0</ixz>
<iyz>0.0</iyz>
<izz>0.1</izz>
</inertia>
</inertial>
<collision name="collision">
<geometry>
<cylinder>
<radius>.1</radius>
</cylinder>
</geometry>
<surface>
<friction>
<ode>
<mu>1.0</mu>
<mu2>1.0</mu2>
<slip1>0</slip1>
<slip2>0</slip2>
</ode>
</friction>
<contact>
<ode>
<kp>1e8</kp>
</ode>
</contact>
</surface>
</collision>
<visual name="left_wheel_visual">
<geometry>
<cylinder>
<radius>.1</radius>
</cylinder>
</geometry>
<material>
<script>
</script>
</material>
</visual>
</link>
<joint type='revolute' name='right_wheel_joint'>
<pose>0 0 -0.025 0 0 0</pose>
<child>right_wheel</child>
<parent>chassis</parent>
<axis>
<xyz>0 1 0</xyz>
</axis>
</joint>
<joint type='revolute' name='left_wheel_joint'>
<child>left_wheel</child>
<axis>
<xyz>0 1 0</xyz>
</axis>
</joint>
<plugin name='barometer_plugin' filename='libgazebo_barometer_plugin.so'>
<robotNamespace/>
<pubRate>50</pubRate>
<baroTopic>/baro</baroTopic>
</plugin>
<plugin name='gazebo_imu_plugin' filename='libgazebo_imu_plugin.so'>
<robotNamespace></robotNamespace>
<linkName>rover/imu_link</linkName>
<imuTopic>/imu</imuTopic>
<gyroscopeNoiseDensity>0.0003394</gyroscopeNoiseDensity>
<gyroscopeRandomWalk>3.8785e-05</gyroscopeRandomWalk>
<gyroscopeBiasCorrelationTime>1000.0</gyroscopeBiasCorrelationTime>
<gyroscopeTurnOnBiasSigma>0.0087</gyroscopeTurnOnBiasSigma>
<accelerometerNoiseDensity>0.004</accelerometerNoiseDensity>
<accelerometerRandomWalk>0.006</accelerometerRandomWalk>
<accelerometerBiasCorrelationTime>300.0</accelerometerBiasCorrelationTime>
<accelerometerTurnOnBiasSigma>0.196</accelerometerTurnOnBiasSigma>
</plugin>
<plugin name="gps_plugin" filename="libgazebo_gps_plugin.so">
<gpsNoise>true</gpsNoise>
</plugin>
<plugin name='magnetometer_plugin' filename='libgazebo_magnetometer_plugin.so'>
<robotNamespace/>
<pubRate>100</pubRate>
<noiseDensity>0.0004</noiseDensity>
<randomWalk>6.4e-06</randomWalk>
<biasCorrelationTime>600</biasCorrelationTime>
<magTopic>/mag</magTopic>
</plugin>
<plugin name='mavlink_interface' filename='libgazebo_mavlink_interface.so'>
<imuSubTopic>/imu</imuSubTopic>
<gpsSubTopic>/gps</gpsSubTopic>
<magSubTopic>/mag</magSubTopic>
<baroSubTopic>/baro</baroSubTopic>
<mavlink_addr>INADDR_ANY</mavlink_addr>
<mavlink_udp_port>14560</mavlink_udp_port>
<serialEnabled>false</serialEnabled>
<serialDevice>/dev/ttyACM0</serialDevice>
<baudRate>921600</baudRate>
<qgc_addr>INADDR_ANY</qgc_addr>
<qgc_udp_port>14550</qgc_udp_port>
<hil_mode>false</hil_mode>
<hil_state_level>false</hil_state_level>
<enable_lockstep>true</enable_lockstep>
<use_tcp>true</use_tcp>
<motorSpeedCommandPubTopic>/gazebo/command/motor_speed</motorSpeedCommandPubTopic>
<control_channels>
<channel name="rear_left_wheel_drive">
<input_index>5</input_index>
<input_offset>0</input_offset>
<input_scaling>40</input_scaling>
<zero_position_disarmed>0</zero_position_disarmed>
<zero_position_armed>0</zero_position_armed>
<joint_control_type>velocity</joint_control_type>
<joint_name>left_wheel_joint</joint_name>
<joint_control_pid>
<p>50</p>
<i>20</i>
<d>2</d>
<iMax>800</iMax>
<iMin>-800</iMin>
<cmdMax>1200</cmdMax>
<cmdMin>-1200</cmdMin>
</joint_control_pid>
</channel>
<channel name="rear_right_wheel_drive">
<input_index>6</input_index>
<joint_name>right_wheel_joint</joint_name>
<joint_control_pid>
<p>50</p>
<i>20</i>
<d>2</d>
<iMax>800</iMax>
<iMin>-800</iMin>
</channel>
</control_channels>
</plugin>
</model>
</sdf>
Any help would be greatly appreciated.
