I am using the follwing SDF file to launch my drone. What I want to do is fix the camera to the drone in such a way that it always faces down irrespective of the drone’s orientation. It should have no changes in orientation whatsoever. How can I do it? The code is -
<?xml version="1.0" encoding="UTF-8"?>
<sdf version='1.9'>
<model name='x500_mono_cam_down'>
<self_collide>false</self_collide>
<include merge='true'>
<uri>x500</uri>
</include>
<uri>model://mono_cam</uri>
<pose>0 0 .10 0 1.5707 0</pose>
<name>mono_cam</name>
</include>
<joint name="CameraJoint" type="fixed">
<parent>base_link</parent>
<child>camera_link</child>
<pose relative_to="base_link">0 0 0 0 1.5707 0</pose>
</joint>
<plugin
filename="gz-sim-odometry-publisher-system"
name="gz::sim::systems::OdometryPublisher">
<dimensions>3</dimensions>
</plugin>
<plugin
filename="gz-sim-joint-state-publisher-system"
name="gz::sim::systems::JointStatePublisher">
</plugin>
<plugin
filename="gz-sim-pose-publisher-system"
name="gz::sim::systems::PosePublisher">
<publish_link_pose>true</publish_link_pose>
<use_pose_vector_msg>true</use_pose_vector_msg>
<static_publisher>true</static_publisher>
<static_update_frequency>1</static_update_frequency>
</plugin>
</model>
</sdf>
