I wonder if it is still possible to develope pixhawk firmware in eclipse.
Unfortunately, really good pages got removed, like: https://pixhawk.org/dev/toolchain_installation_win
which showed a really good tutorial how to install pixhawk with eclipse.
So I wonder if there is any more tutorial out there or is it not longer assisted?
Based on the build output it looks like you have a very old copy of the source, so first I’d update that through git.
Almost all development is done on Linux or MacOS. If it’s currently broken on Windows we can definitely fix it, but you’re much better off setting up a development environment in Linux either natively or through VMWare. Getting access to the right tools will be easier and the compile will be much faster.
