File transfer MAVSDK: Protocol Error
My setup is as follows;
Cube orange connected to companion computer (GPS2 port to USB/serial adpater). GPS2 port is configured as MAVLink port with a baudrate of 115200 and mav forwarding is on.
Additionally I have a herelink control system connected. I am usb tethering the herelink ground unit to a second computer.
I want to send files from the companion computer to the second computer over the mavlink network. I’m currently setting up an FTP server using:
int main(int argc, char** argv)
    if (argc != 4) {
        usage(argv[0]);
        return 1;
    Mavsdk mavsdk;
    Mavsdk::Configuration configuration(Mavsdk::Configuration::UsageType::CompanionComputer);
    mavsdk.set_configuration(configuration);
    ConnectionResult connection_result = mavsdk.add_any_connection("udp://192.168.42.129:14552");
    if (connection_result != ConnectionResult::Success) {
        std::cerr << "Error setting up Mavlink FTP server.\n";
        return 1;
    auto system_cc = mavsdk.systems().at(0);
    auto ftp_server = Ftp{system_cc};
    ftp_server.set_root_directory(argv[3]);
    std::cout << "Mavlink FTP server running.\n"
              << '\n'
              << "Remote:       " << argv[1] << ":" << argv[2] << '\n'
              << "Component ID: " << static_cast<int>(ftp_server.get_our_compid()) << '\n';
    while (true) {
        std::this_thread::sleep_for(std::chrono::seconds(1));
    return 0;
I set up the client (connected to herelink) as follows:
    Mavsdk mavsdk;
    ConnectionResult connection_result = mavsdk.add_any_connection(argv[1]);
        std::cerr << "Connection failed: " << connection_result << '\n';
        return 1;
    auto system = get_system(mavsdk);
    if (!system) {
        return 1;
    // Instantiate plugins.
    auto ftp = Ftp{system};
    try {
        ftp.set_target_compid(std::stoi(argv[2]));
    } catch (...) {
        std::cerr << "Invalid argument: " << argv[2] << '\n';
        return 1;
    Ftp::Result res;
    res = reset_server(ftp);
    if (res != Ftp::Result::Success) {
        std::cerr << "Reset server error: " << res << '\n';
        return 1;
Basically the basic mavsdk example, but changed the connection lines to my setup.
I’m stuck at the following:
I can create a directory (although I get the error “Protocol Error”), but I cannot upload/download any files. Output for downloading file from client:
Download file: ftp_server.cpp to .
[03:41:47|Debug] Component Camera 1 (100) added. (system_impl.cpp:377)
[03:41:47|Warn ] Response timeout. Retry: 1 (mavlink_ftp.cpp:908)
[03:41:48|Warn ] Response timeout. Retry: 2 (mavlink_ftp.cpp:908)
[03:41:48|Warn ] Response timeout. Retry: 3 (mavlink_ftp.cpp:908)
[03:41:48|Warn ] Response timeout. Retry: 4 (mavlink_ftp.cpp:908)
File download error: File Does Not Exist
Output of server:
[03:41:47|Warn ] Wrong sequence - resend last response (mavlink_ftp.cpp:73)
[03:41:47|Warn ] Received NAK without active operation (mavlink_ftp.cpp:347)
[03:41:47|Info ] OPC:CMD_OPEN_FILE_RO (mavlink_ftp.cpp:100)
[03:41:47|Warn ] FTP: Open failed - file not found (mavlink_ftp.cpp:1062)
[03:41:48|Warn ] Wrong sequence - resend last response (mavlink_ftp.cpp:73)
[03:41:48|Warn ] Received NAK without active operation (mavlink_ftp.cpp:347)
Root directory of server is set to current directory, thus the file does exists. Can someone help me solve this?
Another thing: If I try to list the items in a directory, I get the output from the server:
[04:15:00|Warn ] FTP: invalid path /home/mbi/Desktop/alternative-drone/no-commit/MAVSDK/examples/ftp_server (mavlink_ftp.cpp:979)
The path exists and looks valid to me.
Okay, the problem is different than expected. The problem is that uploading works fine, but downloading and listing directories fails. This sound like a permission error to me (although I enabled read, write and execute permissions to the relevant folder). I will open up a new topic for this.
