test@sus:~/Desktop/catkin_ws/src/PX4-Autopilot$ roslaunch px4 posix_sitl.launch... logging to /home/test/.ros/log/14854b44-9852-11ef-ac8c-a14bfa38662b/roslaunch-sus-53684.log
Checking log directory for disk usage. This may take a while.
Press Ctrl-C to interrupt
Done checking log file disk usage. Usage is <1GB.
Resource not found: The following package was not found in <arg name="world" default="$(find mavlink_sitl_gazebo)/worlds/empty.world"/>: mavlink_sitl_gazebo
ROS path [0]=/opt/ros/noetic/share/ros
ROS path [1]=/home/test/Desktop/catkin_ws/src
ROS path [2]=/opt/ros/noetic/share
ROS path [3]=/home/test/Desktop/catkin_ws/src/PX4-Autopilot
ROS path [4]=/home/test/Desktop/catkin_ws/src/PX4-Autopilot/Tools/sitl_gazebo
The traceback for the exception was written to the log file
Yes, I understand that PX4-Autopilot is needless inside the ROS Workspace source. I am on ubuntu 20.04, ros noetic, current px4, earlier in my previous query I had imported an “mavros controller” repo of Jaeyoung-Lim but failed, currently following the above very documentation tutorial. When I am building the catkin workspace, 2 of the 7 packages are not building.
Subsequently, the roslaunch command is throwing error. I also have necessary things sourced.
hmm,
Have you installed Geographic lib?
wget https://raw.githubusercontent.com/mavlink/mavros/master/mavros/scripts/install_geographiclib_datasets.sh
sudo bash ./install_geographiclib_datasets.sh
