DShot + DMA on STM32H743: multi-timer setup leads to stuck outputs and system boot crash
Hi all,
I’m debugging DShot on a custom STM32H743 PX4 board and I now observe a more serious system-level issue that looks like a boot failure / possible memory corruption.
Board info
  • MCU: STM32H743
  • Timer layout same as hkust-nxt-dual
  • HRT uses TIM8 CH1 (TIM2 not used by HRT/RC/tone)
  • 8 outputs enabled
  • TIM1/TIM2/TIM3 all assigned to DMA1
  • Other DMA users: SPI2 + TIM4 only
  • Pins verified working using STM32Cube HAL
DShot behavior
  • TIM1 works fine for PWM and DShot
  • TIM2/TIM3 show abnormal behavior (DShot stuck HIGH)
  • Still debugging DMA/DMAMUX mapping
:police_car_light: Critical issue (boot failure)
When all 8 outputs are configured as DShot:
Symptom A
After reboot:
  • red LED blinking
  • green LED blinks 3 times then off
  • USB not detected by PC
  • board appears completely dead
Only full flash erase + reflash recovers the board.
Symptom B
If SD card remains inserted and I only erase flash:
  • green LED turns solid on
  • still no USB connection
Board does not boot until both flash and SD state are cleared.
My suspicion
This looks like:
  • DMA stream/DMAMUX misconfiguration
  • or multiple timers sharing DMA causing memory corruption
  • possibly overwriting stack/flash/FS during DShot DMA transfers
Because:
  • happens only when many DShot channels enabled
  • persists across reboot
  • requires full erase to recover
Questions
  1. Has anyone seen DMA/DShot causing memory corruption or boot failure on STM32H7?
  2. Is it safe for multiple IO timers to share the same DMA controller/index for DShot?
  3. Is there a recommended way to verify final DMA stream + DMAMUX request mapping at runtime?
  4. Any known restrictions for using DShot on TIM2/TIM3 vs TIM1?
Any debugging suggestions appreciated.
Thanks!
TIM3 could work in PWM mode but TIM2 has no output in PWM mode
Hi all,
Quick update – I managed to find the root cause.
It turned out not to be a DMA / timer / DShot issue.
The problem was a typo in my board defconfig:
CONFIG_PREALLOC_TIMERS=50F
The extra F was accidental.
After correcting it to:
Everything works normally:
  • DShot on all timers OK
  • no stuck outputs
  • no reboot/boot failure
  • no board “brick” behavior
Looks like this misconfiguration probably corrupted memory or broke timer allocation internally, which caused all the strange DMA/boot symptoms.
Sorry for the noise, and hopefully this helps someone in the future :slightly_smiling_face:
Thanks!
