Does anyone successfully use DroneKitPX4 example code from https://dev.px4.io/dronekit-example.html on HILS(Hardware in the Loop Simulation) it’s seem like i am unable to change modes and in jMAVSim the copter fly up a little bit then smash to the ground. the error appeared on terminal is
python DroneKitPX4.py
Connecting
data link #0 regained
Waiting for home position…
Type: 2
Armed: False
System status: STANDBY
GPS: GPSInfo:fix=3,num_sat=10
Alt: -0.025Not switching off HIL (safety)
no valid mission available, refusing takeoff
Exception in message handler for HEARTBEAT
mode 67371008 not available on mavlink definition
ERROR: wp index out of bounds
Executing mission
Takeoff to 498.0 meters above home
Link timeout, no heartbeat in last 5 seconds
…link restored.
ARMED by arm/disarm component command
[blackbox] /fs/microsd/log/2017-02-24
Takeoff detected
[blackbox] recording: 06_16_54.px4log
Do i need to set more parameter apart from change the Airframe to Simulation?
What is “wp index out of bounds” error? and how to fix it, currently, i have to reinstall firmware(px4) to eliminate this problem.
Thank you in advance for any kind of help and sorry for my poor English skill, hope you understand my problem.
