Drone loses armed status after a while
#1
Hi, dear colleges,
I am controlling a drone with pixhawk 2.4.8 with firmware 1.7.3. After defining an identity matrix, I am able to control the PWM that Pixhawk sends to ECSs. The topic that I publish my message is the actuator_control.
However, the drone is able to be armed and be switched into OFFBOARD mode. However, after 5-6s, the drone loses its armed status. I can not find the reason. Is here anyone having the same problem?
`Is seems that the service arming_client.call in my codes can not arm the drone.
Here is the my codes:
void UAVROS::takeoffAndSync()
    ROS_INFO_THROTTLE(10,"take off begings");
    // this target position is just 0.5m above the home position (where the drone is)
    TakeOff_position.pose.position = Home.pose.position;
    TakeOff_position.pose.position.z = Home.pose.position.z+0.5;
    // the target position is initialized to be the home
    Target_position.pose.position = Home.pose.position;
    ros::Time last_request = ros::Time::now();
    ros::Rate takeoff_rate(50);
    offb_set_mode.request.custom_mode = "OFFBOARD";
    arm_cmd.request.value = true;
while ( !(takeoff_pre && ready_in_air) && ros::ok()) //!takeoff_pre || !ready_in_air
      ROS_INFO_THROTTLE(10,"In the loop");
      // receive new sensor data
      takeoff_rate.sleep();
      ros::spinOnce();
      // 1. arm the drone and swtich to the OFFBOAD mode
      if (!mav_state.armed)     //(mav_state.mode != "OFFBOARD") || !mav_state.armed
          ROS_INFO("To arm the drone");
          if( mav_state.mode != "OFFBOARD")
              if(set_mode_client.call(offb_set_mode) &&
                  offb_set_mode.response.mode_sent){
                  ROS_INFO("Offboard enabled");
          if(!mav_state.armed)
                if(arming_client.call(arm_cmd) &&
                      arm_cmd.response.success)
                        ROS_INFO("Vehicle armed");
        //doAttitudeControl(F_arm_lower_limit, 0,0,0);
        doMotorControl(F_arm_lower_limit, 0,0,0);
        ROS_INFO("In arming process");
      // 2. increase the thrust force from the lower limit to the take off
      if ((mav_state.mode == "OFFBOARD") && mav_state.armed && !takeoff_pre)
        ROS_INFO_THROTTLE(1,"prepare to take off");
        F_takeoff_des = 6.5;
        F_takeoff = F_arm_lower_limit + (F_takeoff_des - F_arm_lower_limit)/T_arm *t_takeoff;
        t_takeoff++;
          doMotorControl(F_takeoff, 0,0,0);
        if (F_takeoff == F_takeoff_des)
          takeoff_pre = true;
          ROS_INFO_ONCE("ready to take off");
          ROS_INFO("In prepareing process");
      /* code */
      // 3. control the drone to take off into the air (0.5m above)
      if((mav_state.mode == "OFFBOARD") && mav_state.armed && takeoff_pre && !ready_in_air)
        ROS_INFO("to take off in the air");
        double distance = hypot(hypot(Pose.pose.position.x-TakeOff_position.pose.position.x,
                               Pose.pose.position.y-TakeOff_position.pose.position.y),
                               Pose.pose.position.z-TakeOff_position.pose.position.z);
        if (distance>=0.001)// if the drone is far away from the take_off position at lease 0.2m, we increase the target.z
               // increase the tracking hight a little by little
               if (Target_position.pose.position.z <= TakeOff_position.pose.position.z)
                  Target_position.pose.position.z = Target_position.pose.position.z + 0.01;
               // call the controller to take off in the air
               doTrajectoryTracking(Target_position.pose.position.x, Target_position.pose.position.y, Target_position.pose.position.z, 0);
        else // if the drone is reaching or be stable at the take_off station
              ready_in_air = true;
#2
Hi @robin-ecn ,
This parameter could cause the drone to disarm automatically: https://dev.px4.io/master/en/advanced/parameter_reference.html#COM_DISARM_LAND
Also, in the current version of the code, if the manual kill switch is engaged, the drone disarms after 5 seconds.
It might be difficult to get more help on such an old version of the firmware. What’s preventing you from updating your Pixhawk to the newest release?
#3
Hi, bresch, thanks for your reply. I will test this.
In fact, why i use 1.7.3 is because I was not able to make a simple mixer work in the 1.8.2 and also the mocap/pose was not able to “guide” the drone. That is why I switch back to 1.7.3.
I followed the steps Modifying mixer file without reflashing
my mixer file
M: 1
O:      10000  10000      0 -10000  10000
S: 0 0  10000  10000      0 -10000  10000
M: 1
S: 0 1  10000  10000      0 -10000  10000
M: 1
S: 0 2  10000  10000      0 -10000  10000
M: 1
S: 0 3  10000  10000      0 -10000  10000
