I would like to control a Rover in OFFBOARD mode through MAVROS, e.g. sending position setpoints. I am not sure if this is currently supported in PX4. If it is, I would appreciate if someone points me in the right directions.
I also would like to be able to test both quadcopter and rover concurrently in SITL. Is this also supported, or only one of them can be simulated at a time?
Thanks @Jaeyoung-Lim. I just tried to launch rover in Gazebo using roslaunch px4 mavros_posix_sitl.launch vehicle:=rover
and I noticed that the real-time factor in Gazebo does not reach 1. It’s in the range 0.6-0.7. I am not sure what the bottleneck is. I have a decent machine and I would not expect it to be a limitation as I can run multi-drone simulation with real-time factor 1.
The original Gazebo model does not slow down the simulation. So it is most probably related to the additions and plugins that are added to interface it to PX4
Have you found a solution for this issue? I’m facing the same problem, using PX4 v.1.11.
Actually, using any two different vehicles will kill the real-time factor, which drops to 0.1.
