CUAV X7+ Pro Maximum Speed Limit using QGC(PX4)
Dear Dev. Team,
I am using Px4 firmware and Qground control for CUAV X7 Pro.
  1. My goal is to achieve drone speed of more than 250 m/Sec(or 720km/hr) by using CUAV X7+ Pro.
  2. Is it possible to achieve that speed by using that Autopilot ?
  3. if not possible, how much maximum speed , we can achieve by using CUAV.
  4. The maximum speed limit in Qground control is 40m/sec, would it possible to change that limit?
NOTE: I have V-tail Fixed Wing Drone using Jet Engine.
This is nothing to do with your flight controller board (CUAV). It will be a function of what the flight stack (PX4) and your hardware allow.
You can change the max speed in QGC easily enough but I suspect that this probably reflects the maximum value of a parameter in PX4. Further, I am sure that you could change the parameter maximum too, but then you’d be in uncharged territory - how much of the other tuning etc would apply I do not know.
@sfuhrer If someone wanted to try this, is it theoretically possible by changing maximum values of params etc or is it “unknown”.
Dear sir,
let’s assume that i change the speed parameter to 100m/sec in QGC but how to simulate that speed in flight gear. As rascal plane in PX4 firmware is unable to achieve that speed.
Yes a lot of PX4 parameters (settings) have quite random min/max values, that are usually set to the “normal” operation range of “normal” drones. I’m not a fan of these random constraints, but opinions differ. You can always overwrite them by “force saving” a parameter.
There is no simulation vehicle existing that flies even close to the speed.
