Had a similar experience with my Pixhawk on a quad using Radiolonk at9 controller using QGC to do auto takeoff and used controller to change flight mode to land then accidentally flipped the land mode switch off and all quad motors stopped and quad feel the last 20 feet not sure why, or what should have happen,
how do you download the log files and will logs reveal cause
Thanks
it seems to me that the scenario you describe happened to me in the flight preceding the crash.
I lost control at one point and pressed the buttons to change mode by accident, suddenly my drone ended up in the tree at the neighbor’s house … https://review.px4.io/plot_app?log=eff62947-810f-4625-9420-ebbbcccd3b83
in my case I was altitude mode for 15 minutes and I have not changed mode during this flight, we see it in the logs.
but I can not find the answer in the logs.
if someone more experienced could watch and tell me what happened …
Thanks for the reply, in my case I activated my land switch and then deactivated it by mistake
At about 20 ft off the ground and the motors just stop spinning and the quad fell.
What is the process for getting my flight logs from my Pixhawk FC , are they on the SD card
You need to fix your hardware setup. The measured magnetic field is experiencing heavy interference. In addition you have high noise reported on your GPS.
This means that the state estimator has experienced a navigation failure and is resetting your height estimate to your primary height source, which in your case is the barometer
in relation to your answer do you have an idea of how I can do to reduce the magnetic field and the interferences of my GPS, what could the disturbing elements be?
and thank you for the clarification on this error message although I am really surprised the result obtained in this case => crash.
could my barometer have a problem in your opinion?
