Crash due to stuck Lidar despite Baro & GPS Data
Do you use a Garmin lidar lite? In that case it is a classic failure of the sensor, the EKF even has some protection implemented to reduce the problem.
Either the driver has to be reworked (might help according to Garmin) or you can add logic to handle the failure case for your application.
