Control Drone
Hi, i have a question is does MAVSDK-python can control drone with its firmware is Ardupilot 4.3.4 ?!
It depends what you’re trying to do. Compatibility with ArduPilot is work in progress. Some things work, and others not so much.
Tks for you reply, the error below appear when i try to take off Drone (firmware Ardupilot) with MAVSDK command.
i check, this parameter doesn’t exist at Ardupilot firmware =((
