Connecting Pixhawk 6C to LattePanda 3 Delta 864
Hi everyone,
I’m currently working on a project where I need to connect a Pixhawk 6C flight controller to a LattePanda 3 Delta 864. My goal is to establish a reliable serial communication between the two devices for control purposes.
Has anyone here successfully connected a Pixhawk 6C to a LattePanda 3 Delta 864 before? If so, could you share your experience and how exactly and with what type of wiring I should connect the devices?
Thanks in advance!
In case you can’t figure out the serial connection of the LattePanda itself, you can always just connect an FTDI cable on USB and use that.
