Hey all,
I can compile just fine from the command line (macOS Catalina). However when I want to use VSCode, I get the following error:
The path to the compiler for one or more source files was not found in the CMake cache. If you are using a toolchain file, this probably means that you need to specify the CACHE option when you set your C and/or C++ compiler path
But the build seems to finish ok (exit code 0).
And a bonus warning:
[cmakefileapi-parser] Code model version (2.1) of cmake-file-api is unexpected. Expecting (2.0). IntelliSense configuration may be incorrect.
Any ideas on either of those errors/warnings?
