Can't build SIH firmware for ARKV6X
In boards/ark/fmu-v6x, I made a file called sih.px4board with only one line: CONFIG_MODULES_SIMULATION_SIMULATOR_SIH=y
But when I run make ark_fmu-v6x_sih to build the SIH firmware, I get a flash overflow error. This is strange because if I repeat this process for the Cube Orange+, the SIH firmware builds successfully.
Here’s the error:
FAILED: ark_fmu-v6x_sih.elf
Memory region         Used Size  Region Size  %age Used
        ITCM_RAM:          0 GB        64 KB      0.00%
           FLASH:     1990348 B      1920 KB    101.23%
       DTCM1_RAM:          0 GB        64 KB      0.00%
       DTCM2_RAM:          0 GB        64 KB      0.00%
        AXI_SRAM:       99272 B       512 KB     18.93%
           SRAM1:          0 GB       128 KB      0.00%
           SRAM2:          0 GB       128 KB      0.00%
           SRAM3:          0 GB        32 KB      0.00%
           SRAM4:          2 KB        64 KB      3.12%
          BKPRAM:          0 GB         4 KB      0.00/opt/gcc-arm-none-eabi-9-2020-q2-update/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/bin/ld: ark_fmu-v6x_sih.elf section `.text' will not fit in region `FLASH'
/opt/gcc-arm-none-eabi-9-2020-q2-update/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/bin/ld: region `FLASH' overflowed by 24268 bytes
collect2: error: ld returned 1 exit status
make: *** [Makefile:227: ark_fmu-v6x_sih] Error 1
Try with current main. If that still doesn’t fit, turn off some unused modules.
I just built current main with CONFIG_MODULES_SIMULATION_SIMULATOR_SIH=y and it barely fits.
[1179/1181] Linking CXX executable ark_fmu-v6x_default.elf
FLASH: 1964168 B 1920 KB 99.90%
AXI_SRAM: 99528 B 512 KB 18.98%
BKPRAM: 0 GB 4 KB 0.00%
[1181/1181] Creating /home/alex/PX4-Autopilot/build/ark_fmu-v6x_default/ark_fmu-v6x_default.px4
alex@alex-desktop:~/PX4-Autopilot$
Thank you that worked!
