I have a quadplane set up with all actuators commanded by DRONECAN (ESCs themself use PWM, so I use CAN-PWM adapters). However, the arming process for the motors is a bit cumbersome. Since I have decided to have the lifting motors run at an idle-setting when armed, I have to arm, then disarm and arm again for the ESCs to actually arm and get ready. Ideally, I would have liked the possibility to set a disarmed value for CAN ESCs, and have that be pushed when I push the prearm button.
Related topics
| Topic | Replies | Views | Activity | |
| ESC using CAN2.0 protocol | 0 | 334 | February 4, 2021 | |
| Something similar to LUA script in PX4 | 0 | 641 | October 30, 2023 | |
| Hobbywing CAN ESCs | 18 | 189 | March 20, 2026 | |
| Hobbywing UAVcan/Dronecan ESC (x6plus/h6m/x9) | 5 | 848 | May 14, 2025 | |
| Pixhawk 4 Motor/ESC Arming | 1 | 1348 | October 11, 2019 |
