Hey, I’m using FollowMe plugin to making one drone follow another and I don’t know how to stream drone position to TargetLocation; I know in Java i can use Flowables, but how to do that in C++?
You can either loop and poll the position with position() or set it when you get a callback with the new position using subscribe_position().
There is also an example here: https://github.com/mavlink/MAVSDK/tree/develop/examples/follow_me
Are you trying to follow yourself with the drone?
nah, I’m try to make one drone follow another; now after I’m starting FollowMe plugin, it stucks on
[09:27:59|Debug] Waiting for the system confirmation of the new configuration.. (follow_me_impl.cpp:93)
followMe plugin config:
followMeConfig.follow_distance_m = 5.0f;
followMeConfig.responsiveness = 0.2f;
followMeConfig.follow_direction = FollowMe::Config::FollowDirection::Behind;
Edit: this should work, I think.
Does the integration test work for you?
You can run it with:
cmake --build build/default -j8 && build/default/src/integration_tests/integration_tests_runner --gtest_filter="SitlTest.FollowMe*"
Tests failed…
Note: Google Test filter = SitlTest.FollowMe*
[==========] Running 2 tests from 1 test suite.
[----------] Global test environment set-up.
[----------] 2 tests from SitlTest
[ RUN ] SitlTest.FollowMeOneLocation
[12:24:43|Debug] Model chosen: 'iris' (integration_test_helper.h:59)
SITL model: iris
Not autostarting SITL (use AUTOSTART_SITL=1)
[12:24:43|Info ] MAVSDK version: 0.26.0-19-g10812a40 (mavsdk_impl.cpp:26)
[12:24:45|Debug] New: System ID: 0 Comp ID: 0 (mavsdk_impl.cpp:380)
/home/kris/MAVSDK/src/integration_tests/follow_me.cpp:34: Failure
Value of: system.has_autopilot()
Actual: false
Expected: true
[ FAILED ] SitlTest.FollowMeOneLocation (3012 ms)
[ RUN ] SitlTest.FollowMeMultiLocationWithConfig
[12:24:46|Debug] Model chosen: 'iris' (integration_test_helper.h:59)
SITL model: iris
[12:24:46|Info ] MAVSDK version: 0.26.0-19-g10812a40 (mavsdk_impl.cpp:26)
/home/kris/MAVSDK/src/integration_tests/follow_me.cpp:108: Failure
Value of: poll_condition_with_timeout( [&mavsdk]() { return mavsdk.is_connected(); }, std::chrono::seconds(10))
Actual: false
Expected: true
[ FAILED ] SitlTest.FollowMeMultiLocationWithConfig (12015 ms)
[----------] 2 tests from SitlTest (15027 ms total)
[----------] Global test environment tear-down
[==========] 2 tests from 1 test suite ran. (15027 ms total)
[ PASSED ] 0 tests.
[ FAILED ] 2 tests, listed below:
2 FAILED TESTS
So nothing is connecting. How are you connecting to th drone?
I just simulate them in Gazebo
EDIT: I launched 1 drone in Gazebo, and tested it
[06:50:56|Debug] Model chosen: 'iris' (integration_test_helper.h:59)
SITL model: iris
[06:50:56|Info ] MAVSDK version: 0.26.0-19-g10812a40 (mavsdk_impl.cpp:26)
[06:50:56|Info ] New system on: 127.0.0.1:14580 (udp_connection.cpp:256)
[06:50:56|Debug] New: System ID: 1 Comp ID: 1 (mavsdk_impl.cpp:380)
[06:50:56|Debug] Component Autopilot (1) added. (system_impl.cpp:352)
[06:50:56|Debug] Discovered 1 component(s) (UUID: 5283920058631409231) (system_impl.cpp:525)
waiting for system to be ready
[06:50:59|Debug] MAVLink: info: ARMED by Arm/Disarm component command (system_impl.cpp:257)
[06:50:59|Debug] MAVLink: info: Using minimum takeoff altitude: 2.50 m (system_impl.cpp:257)
[FlightMode: Takeoff] Vehicle is at Lat: nan deg, Lon: nan deg.
[06:51:00|Debug] MAVLink: info: Takeoff detected (system_impl.cpp:257)
[FlightMode: Hold] Vehicle is at Lat: nan deg, Lon: nan deg.
Current FollowMe configuration of the system
Min Height: 8m
Distance: 8m
Responsiveness: 0.5
Following from: Behind
[FlightMode: Follow Me] Vehicle is at Lat: nan deg, Lon: nan deg.
We're waiting (for 5s) to see the drone moving target location set.
[FlightMode: Follow Me] Vehicle is at Lat: 47.3977 deg, Lon: 8.54564 deg.
[FlightMode: Hold] Vehicle is at Lat: 47.3977 deg, Lon: 8.54564 deg.
[06:51:12|Debug] MAVLink: info: Landing at current position (system_impl.cpp:257)
[FlightMode: Land] Vehicle is at Lat: 47.3977 deg, Lon: 8.54564 deg.
waiting for system to disarm
[06:51:24|Debug] MAVLink: info: Landing detected (system_impl.cpp:257)
[06:51:24|Debug] MAVLink: info: DISARMED by Auto disarm initiated (system_impl.cpp:257)
[ OK ] SitlTest.FollowMeOneLocation (30112 ms)
[06:51:26|Debug] Model chosen: 'iris' (integration_test_helper.h:59)
SITL model: iris
[06:51:26|Info ] MAVSDK version: 0.26.0-19-g10812a40 (mavsdk_impl.cpp:26)
[06:51:26|Info ] New system on: 127.0.0.1:14580 (udp_connection.cpp:256)
[06:51:26|Debug] New: System ID: 1 Comp ID: 1 (mavsdk_impl.cpp:380)
[06:51:26|Debug] Component Autopilot (1) added. (system_impl.cpp:352)
[06:51:26|Debug] Discovered 1 component(s) (UUID: 5283920058631409231) (system_impl.cpp:525)
Waiting for system to be ready
[06:51:29|Debug] MAVLink: info: ARMED by Arm/Disarm component command (system_impl.cpp:257)
[06:51:29|Debug] MAVLink: info: [logger] ./log/2020-06-08/04_51_29.ulg (system_impl.cpp:257)
[06:51:29|Debug] MAVLink: info: Using minimum takeoff altitude: 2.50 m (system_impl.cpp:257)
[06:51:30|Debug] MAVLink: info: Takeoff detected (system_impl.cpp:257)
[06:51:34|Debug] Waiting for the system confirmation of the new configuration.. (follow_me_impl.cpp:93)
# of Target locations: 25 @ Rate: 1Hz.
[FlightMode: Follow Me] Vehicle is at Lat: 47.3977 deg, Lon: 8.54567 deg.
[FlightMode: Follow Me] Vehicle is at Lat: 47.3977 deg, Lon: 8.54569 deg.
[FlightMode: Follow Me] Vehicle is at Lat: 47.3977 deg, Lon: 8.5457 deg.
[FlightMode: Follow Me] Vehicle is at Lat: 47.3977 deg, Lon: 8.54571 deg.
[FlightMode: Follow Me] Vehicle is at Lat: 47.3978 deg, Lon: 8.54572 deg.
[FlightMode: Follow Me] Vehicle is at Lat: 47.3978 deg, Lon: 8.54571 deg.
[FlightMode: Follow Me] Vehicle is at Lat: 47.3978 deg, Lon: 8.5457 deg.
[FlightMode: Follow Me] Vehicle is at Lat: 47.3978 deg, Lon: 8.54568 deg.
[FlightMode: Follow Me] Vehicle is at Lat: 47.3978 deg, Lon: 8.54567 deg.
[FlightMode: Follow Me] Vehicle is at Lat: 47.3978 deg, Lon: 8.54564 deg.
[FlightMode: Follow Me] Vehicle is at Lat: 47.3977 deg, Lon: 8.54552 deg.
[FlightMode: Follow Me] Vehicle is at Lat: 47.3978 deg, Lon: 8.54559 deg.
[FlightMode: Follow Me] Vehicle is at Lat: 47.3978 deg, Lon: 8.54557 deg.
[FlightMode: Follow Me] Vehicle is at Lat: 47.3977 deg, Lon: 8.54554 deg.
[FlightMode: Follow Me] Vehicle is at Lat: 47.3978 deg, Lon: 8.54553 deg.
[FlightMode: Follow Me] Vehicle is at Lat: 47.3997 deg, Lon: 8.5427 deg.
[FlightMode: Follow Me] Vehicle is at Lat: 47.3978 deg, Lon: 8.54555 deg.
[FlightMode: Follow Me] Vehicle is at Lat: 47.3978 deg, Lon: 8.54554 deg.
[FlightMode: Follow Me] Vehicle is at Lat: 47.3977 deg, Lon: 8.54553 deg.
[FlightMode: Hold] Vehicle is at Lat: 47.3977 deg, Lon: 8.54553 deg.
[06:52:01|Debug] MAVLink: info: Landing at current position (system_impl.cpp:257)
[FlightMode: Land] Vehicle is at Lat: 47.3977 deg, Lon: 8.54553 deg.
[06:52:17|Debug] MAVLink: info: Landing detected (system_impl.cpp:257)
[06:52:18|Debug] MAVLink: info: DISARMED by Auto disarm initiated (system_impl.cpp:257)
[ OK ] SitlTest.FollowMeMultiLocationWithConfig (54138 ms)
[----------] 2 tests from SitlTest (84250 ms total)
[==========] 2 tests from 1 test suite ran. (84251 ms total)
[ PASSED ] 2 tests.
Ok, it seems like that worked.
since after MAVSDK update FollowMe still doesn’t work I’ll send my whole code, because I don’t know what I’m doing wrong…
#include <chrono>
#include <future>
#include <iostream>
#include <mavsdk/plugins/action/action.h>
#include <mavsdk/plugins/telemetry/telemetry.h>
#include <mavsdk/plugins/offboard/offboard.h>
#include <mavsdk/plugins/follow_me/follow_me.h>
#include <mavsdk/mavsdk.h>
using namespace std;
using namespace mavsdk;
using chrono::seconds;
using this_thread::sleep_for;
#define ERROR_CONSOLE_TEXT "\033[31m"
#define NORMAL_CONSOLE_TEXT "\033[0m"
inline void handleActionError(Action::Result result, const string& message);
inline void handleFollowMeError(FollowMe::Result result, const string& message);
inline void handleOffboardError(Offboard::Result result, const string& message);
static int flyOffboard(System& system);
static int followDrone(System& leader, System& follower);
bool offboardTour(shared_ptr<Offboard> ob);
Telemetry::LandedStateCallback landedStateCallback(shared_ptr<Telemetry>& telemetry, promise<void>& promise);
Telemetry::PositionCallback positionCallback(shared_ptr<FollowMe>& followMe);
static int flyOffboard(System& system){
auto action = make_shared<Action>(system);
auto offboard = make_shared<Offboard>(system);
auto telemetry = make_shared<Telemetry>(system);
const Telemetry::Result setRateResult = telemetry->set_rate_position(1);
if(setRateResult!=Telemetry::Result::Success){
cout << ERROR_CONSOLE_TEXT
<< "Setting rate failed:" << setRateResult
<< NORMAL_CONSOLE_TEXT << endl;
return EXIT_FAILURE;
while (!telemetry->health_all_ok()) {
sleep_for(seconds(1));
promise<void> inAirPromise;
auto inAirFuture = inAirPromise.get_future();
cout << "Drone 1 arming..."<<endl;
const Action::Result armResult = action->arm();
handleActionError(armResult,"ARM FAILED\n");
cout << "Drone 1 armed";
const Action::Result takeOffResult = action->takeoff();
handleActionError(takeOffResult,"TAKEOFF FAILED\n");
telemetry->subscribe_landed_state(landedStateCallback(telemetry,inAirPromise));
inAirFuture.wait();
bool ret= offboardTour(offboard);
if (!ret){
const Action::Result landResult = action->land();
handleActionError(landResult,"LANDING FAILED\n");
while (telemetry->in_air()) {
cout << "Landing..." << endl;
cout << "Landed!" << endl;
sleep_for(seconds(3));
cout << "Bye! ;)" << endl;
return EXIT_SUCCESS;
static int followDrone(System& leader, System& follower){
auto followMe = make_shared<FollowMe>(follower);
auto action = make_shared<Action>(follower);
auto followerTelemetry = make_shared<Telemetry>(follower);
auto leaderTelemetry = make_shared<Telemetry>(leader);
Telemetry::Result setRateResult = followerTelemetry->set_rate_position(1);
setRateResult = leaderTelemetry->set_rate_position(1);
while (!followerTelemetry->health_all_ok()) {
cout << "Drone 2 arming..."<<endl;
cout << "Drone 2 armed";
followerTelemetry->subscribe_landed_state(landedStateCallback(followerTelemetry, inAirPromise));
inAirFuture.wait();
FollowMe::Config followMeConfig;
FollowMe::Result configResult = followMe->set_config(followMeConfig);
if(configResult!=FollowMe::Result::Success){
<< "Setting configuration failed:" << configResult
FollowMe::Result followMeResult = followMe->start();
handleFollowMeError(followMeResult,"FOLLOWME PLUGIN FAILED\n");
leaderTelemetry->subscribe_position(positionCallback(followMe));
//followMe->set_target_location();
return 0;
inline void handleActionError(Action::Result result, const string& message){
if(result != Action::Result::Success){
cerr << ERROR_CONSOLE_TEXT << message << result << NORMAL_CONSOLE_TEXT<< endl;
exit(EXIT_FAILURE);
inline void handleFollowMeError(FollowMe::Result result, const string& message){
if(result != FollowMe::Result::Success){
exit(EXIT_FAILURE);
inline void handleOffboardError(Offboard::Result result, const string& message){
if(result != Offboard::Result::Success){
exit(EXIT_FAILURE);
Telemetry::LandedStateCallback landedStateCallback(shared_ptr<Telemetry>& telemetry, promise<void>& promise) {
return [&promise,&telemetry](Telemetry::LandedState landed){
switch (landed){
case Telemetry::LandedState::OnGround:
std::cout << "On ground" << std::endl;
break;
case Telemetry::LandedState::TakingOff:
std::cout << "Taking off..." << std::endl;
break;
case Telemetry::LandedState::Landing:
std::cout << "Landing..." << std::endl;
break;
case Telemetry::LandedState::InAir:
std::cout << "Taking off has finished." << std::endl;
telemetry->subscribe_landed_state(nullptr);
promise.set_value();
break;
case Telemetry::LandedState::Unknown:
std::cout << "Unknown landed state." << std::endl;
break;
Telemetry::PositionCallback positionCallback(shared_ptr<FollowMe>& followMe){
return [&followMe](Telemetry::Position position){
FollowMe::TargetLocation target{};
target.latitude_deg = position.latitude_deg;
target.longitude_deg = position.longitude_deg;
target.absolute_altitude_m = position.absolute_altitude_m;
followMe->set_target_location(target);
cout<<target.latitude_deg<<target.longitude_deg<<target.absolute_altitude_m<<endl;
bool offboardTour(shared_ptr<Offboard> ob){
Offboard::VelocityNedYaw point;
point.north_m_s = 0;
point.east_m_s = 0;
point.down_m_s = 0;
point.yaw_deg = 0;
ob->set_velocity_ned(point);
Offboard::Result obResult = ob->start();
handleOffboardError(obResult,"OFFBOARD FAILED\n");
cout<<"Offboard started"<<endl;
point.down_m_s = -5;
point.down_m_s = 0;
point.east_m_s = 5;
point.yaw_deg = 90;
sleep_for(seconds(5));
point.north_m_s = -5;
point.east_m_s = 0;
point.yaw_deg = 180;
point.east_m_s = -5;
point.yaw_deg = 270;
point.north_m_s = 5;
point.east_m_s = 0;
point.yaw_deg = 0;
obResult = ob->stop();
cout<<"Offboard stopped"<<endl;
return true;
int main() {
Mavsdk dc;
ConnectionResult connectionResult[2];
connectionResult[0] = dc.add_any_connection("udp://127.0.0.1:14540");
connectionResult[1] = dc.add_any_connection("udp://127.0.0.1:14541");
for (auto & i : connectionResult){
if (i != ConnectionResult::Success) {
<< "Connection failed: " << i
return 1;
atomic<signed> systemsCount{0};
cout << "Waiting to discover systems..." << endl;
vector<uint64_t> uuids;
dc.register_on_discover([&systemsCount,&uuids](uint64_t uuid) {
cout << "Discovered system with UUID: " << uuid << endl;
uuids.push_back(uuid);
systemsCount++;
if (systemsCount != 2) {
cerr << ERROR_CONSOLE_TEXT << "Not all systems found, exiting." << NORMAL_CONSOLE_TEXT
<< endl;
return 1;
vector<thread> threads;
System& system1 = dc.system(uuids[0]);
System& system2 = dc.system(uuids[1]);
thread t1(&flyOffboard, ref(system1));
thread t2(&followDrone, ref(system1),ref(system2));
//t1.join();
threads.push_back(move(t1));
threads.push_back(move(t2));
for (auto& t : threads){
t.join();
return 0;
Ok, when you say “it doesn’t work” what happens exactly?
The drone, which should follow the other one, just stops instead of that; in command line FollowMe stops at
[07:49:42|Debug] Waiting for the system confirmation of the new configuration.. (follow_me_impl.cpp:93)
and positionCallback is not working…
Ok, have you made sure that the follow me example for just one drone works properly?
just checked and example works fine; IMHO somewhere in my code is a error…
I think you’re locking yourself out somehow.
I suggest to do the following.
Start the application with gdb, so gdb --args yourapp --your_args, then do run and wait until it is stuck.
Then you hit Ctrl+C, and type: thread apply all backtrace, and then you copy the output here.
ok, since it’s multi thread app, something could escape the debugger; nonetheless here’s the output:
Thread 12 (Thread 0x7fffecff9700 (LWP 3900)):
#0 0x00007ffff6ab8c60 in __GI___nanosleep (requested_time=0x7fffecff8c30,
remaining=0x7fffecff8c30) at ../sysdeps/unix/sysv/linux/nanosleep.c:28
#1 0x0000555555577405 in std::this_thread::sleep_for<long, std::ratio<1l, 1l> > (__rtime=...) at /usr/include/c++/7/thread:373
#2 0x00005555555741b0 in offboardTour (
ob=std::shared_ptr<mavsdk::Offboard> (use count 2, weak count 0) = {...})
at /home/kris/CLionProjects/twoDrones/main.cpp:229
#3 0x0000555555573205 in flyOffboard (system=...)
at /home/kris/CLionProjects/twoDrones/main.cpp:66
#4 0x0000555555578dce in std::__invoke_impl<int, int (*)(mavsdk::System&), std::reference_wrapper<mavsdk::System> > (
__f=@0x55555579b8e0: 0x555555572f05 <flyOffboard(mavsdk::System&)>)
at /usr/include/c++/7/bits/invoke.h:60
#5 0x00005555555777ec in std::__invoke<int (*)(mavsdk::System&), std::reference_wrapper<mavsdk::System> > (
__fn=@0x55555579b8e0: 0x555555572f05 <flyOffboard(mavsdk::System&)>)
at /usr/include/c++/7/bits/invoke.h:96
#6 0x000055555557e433 in std::thread::_Invoker<std::tuple<int (*)(mavsdk::System&), std::reference_wrapper<mavsdk::System> > >::_M_invoke<0ul, 1ul> (
this=0x55555579b8d8) at /usr/include/c++/7/thread:234
---Type <return> to continue, or q <return> to quit---
m&), std::reference_wrapper<mavsdk::System> > >::operator() (this=0x55555579b8d8) at /usr/include/c++/7/thread:243
#8 0x000055555557e0b4 in std::thread::_State_impl<std::thread::_Invoker<std::tuple<int (*)(mavsdk::System&), std::reference_wrapper<mavsdk::System> > > >::_M_run (this=0x55555579b8d0)
at /usr/include/c++/7/thread:186
#9 0x00007ffff6f9b6df in ?? () from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
#10 0x00007ffff6aae6db in start_thread (arg=0x7fffecff9700) at pthread_create.c:463
#11 0x00007ffff67d788f in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:95
Thread 11 (Thread 0x7fffed7fa700 (LWP 3881)):
#0 0x00007ffff6ab49f3 in futex_wait_cancelable (private=<optimized out>, expected=0, futex_word=0x7fffe80012f8) at ../sysdeps/unix/sysv/linux/futex-internal.h:88
#1 __pthread_cond_wait_common (abstime=0x0, mutex=0x7fffe80012a8, cond=0x7fffe80012d0) at pthread_cond_wait.c:502
#2 __pthread_cond_wait (cond=0x7fffe80012d0, mutex=0x7fffe80012a8) at pthread_cond_wait.c:655
#3 0x00007ffff6f958bc in std::condition_variable::wait(std::unique_lock<std::mutex>&) () from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
#4 0x00007ffff7304369 in mavsdk::ThreadPool::worker() () from /usr/local/lib/libmavsdk.so
#5 0x00007ffff6f9b6df in ?? () from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
#6 0x00007ffff6aae6db in start_thread (arg=0x7fffed7fa700) at pthread_create.c:463
#7 0x00007ffff67d788f in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:95
Thread 10 (Thread 0x7fffedffb700 (LWP 3880)):
#0 0x00007ffff6ab49f3 in futex_wait_cancelable (private=<optimized out>, expected=0, futex_word=0x7fffe80012fc) at ../sysdeps/unix/sysv/linux/futex-internal.h:88
#6 0x00007ffff6aae6db in start_thread (arg=0x7fffedffb700) at pthread_create.c:463
Thread 9 (Thread 0x7fffee7fc700 (LWP 3879)):
#6 0x00007ffff6aae6db in start_thread (arg=0x7fffee7fc700) at pthread_create.c:463
Thread 8 (Thread 0x7fffeeffd700 (LWP 3878)):
#0 0x00007ffff6ab8c60 in __GI___nanosleep (requested_time=0x7fffeeffce90, remaining=0x7fffeeffce90) at ../sysdeps/unix/sysv/linux/nanosleep.c:28
#1 0x00007ffff72a37ba in mavsdk::SystemImpl::system_thread() () from /usr/local/lib/libmavsdk.so
#2 0x00007ffff6f9b6df in ?? () from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
#3 0x00007ffff6aae6db in start_thread (arg=0x7fffeeffd700) at pthread_create.c:463
#4 0x00007ffff67d788f in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:95
Thread 7 (Thread 0x7fffef7fe700 (LWP 3877)):
#0 0x00007ffff6ab49f3 in futex_wait_cancelable (private=<optimized out>, expected=0, futex_word=0x7ffff00012f8) at ../sysdeps/unix/sysv/linux/futex-internal.h:88
#1 __pthread_cond_wait_common (abstime=0x0, mutex=0x7ffff00012a8, cond=0x7ffff00012d0) at pthread_cond_wait.c:502
#2 __pthread_cond_wait (cond=0x7ffff00012d0, mutex=0x7ffff00012a8) at pthread_cond_wait.c:655
#6 0x00007ffff6aae6db in start_thread (arg=0x7fffef7fe700) at pthread_create.c:463
Thread 6 (Thread 0x7fffeffff700 (LWP 3876)):
#6 0x00007ffff6aae6db in start_thread (arg=0x7fffeffff700) at pthread_create.c:463
Thread 5 (Thread 0x7ffff4b14700 (LWP 3875)):
#0 0x00007ffff6ab49f3 in futex_wait_cancelable (private=<optimized out>, expected=0, futex_word=0x7ffff00012fc) at ../sysdeps/unix/sysv/linux/futex-internal.h:88
#6 0x00007ffff6aae6db in start_thread (arg=0x7ffff4b14700) at pthread_create.c:463
Thread 4 (Thread 0x7ffff5315700 (LWP 3874)):
#0 0x00007ffff6ab8c60 in __GI___nanosleep (requested_time=0x7ffff5314e90, remaining=0x7ffff5314e90) at ../sysdeps/unix/sysv/linux/nanosleep.c:28
#3 0x00007ffff6aae6db in start_thread (arg=0x7ffff5315700) at pthread_create.c:463
Thread 3 (Thread 0x7ffff5b16700 (LWP 3873)):
#0 0x00007ffff6ab88f2 in __libc_recvfrom (fd=4, buf=0x7ffff5b15690, len=2048, flags=0, addr=..., addrlen=0x7ffff5b153fc) at ../sysdeps/unix/sysv/linux/recvfrom.c:27
#1 0x00007ffff72fbc4a in mavsdk::UdpConnection::receive() () from /usr/local/lib/libmavsdk.so
#3 0x00007ffff6aae6db in start_thread (arg=0x7ffff5b16700) at pthread_create.c:463
Thread 2 (Thread 0x7ffff6317700 (LWP 3872)):
#0 0x00007ffff6ab88f2 in __libc_recvfrom (fd=3, buf=0x7ffff6316690, len=2048, flags=0, addr=..., addrlen=0x7ffff63163fc) at ../sysdeps/unix/sysv/linux/recvfrom.c:27
#3 0x00007ffff6aae6db in start_thread (arg=0x7ffff6317700) at pthread_create.c:463
Thread 1 (Thread 0x7ffff7fac740 (LWP 3867)):
#0 0x00007ffff6aafd2d in __GI___pthread_timedjoin_ex (threadid=140737169561344, thread_return=0x0, abstime=0x0, block=<optimized out>) at pthread_join_common.c:89
#1 0x00007ffff6f9b933 in std::thread::join() () from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
#2 0x00005555555748ae in main () at /home/kris/CLionProjects/twoDrones/main.cpp:296
I see that it’s going through your offboardTour function but I doubt that’s where it actually locks, right?
yep, IMO problem is in function followDrone at line
it’s supposed to take position from leader drone for making targetPosition for Follow me plugin of follower drone…
the whole problem is I don’t know how to make subsrcibe_position work…
Is it never called? Or only once?
when debugged in CLion, it once goes to line leaderTelemetry->subscribe_position(positionCallback(followMe));, where callback is positioned but it doesn’t go to breakpoint in positionCallback function…
