Hi all,
I started with DJI mainly to understand mapping workflows (WebODM for ortho/3D, GPS geotagging, etc.). That part works. But for my real use case, the closed ecosystem hits limits.
Business case
Environment: Vineyards with ~1.5–2.0 m row spacing, canopy ~2 m high, sloped terrain.
Goal: Detailed leaf inspection (including near the base) and a consistent 3D map of the rows.
Flight profile: Very low altitude (≈1–2 m AGL), down long corridors between rows; repeatable routes over the season.
Constraints: Safety/obstacle avoidance in dense vegetation, stable imagery (no blur), precise georef to fuse multiple passes.
My background
I’m strong on computer vision / TensorFlow (segmentation, classification); I’m new to building the aircraft itself.
What I’m confused about (approach-wise)
There seem to be multiple ways to skin this, and I’d love guidance on which approach you’d pick and why:
Open flight stack + companion
ArduPilot or PX4 + companion computer (e.g., Raspberry Pi 5 + Coral/Hailo).
Navigation: V-SLAM (RTAB-Map / ORB-SLAM3 / ROS2) with stereo/RGB-D (RealSense / OAK-D / ZED).
Pros/cons in vineyards? Reliability between dense rows, low-alt terrain following, failure modes, tuning gotchas?
SLAM-light + RTK + “structured” missions
Rely on RTK GNSS + carefully planned corridors/facades, do obstacle sensing with stereo/rangefinder mainly as safety, not primary nav.
Enough for stable 1–2 m AGL flights between vines? Or will vegetation dynamics make this too brittle?
Hybrid / staged
UGV first to validate the SLAM + perception stack in the rows, then port to drone.
If you’ve done this: did it save time vs going airborne straight away?
Concrete asks:
Hardware stack you’d actually buy today (frame size, motors/ESC, FC—Pixhawk/Cube—, GNSS/RTK, companion, camera/gimbal, lidar/rangefinder).
Software stack you trust for this: ArduPilot vs PX4, ROS2 nodes (MAVROS/MicroXRCE-DDS), SLAM choice, mapping pipeline → WebODM.
Camera advice for leaf-level detail at low speed: global vs rolling shutter, lens FOV, exposure control, anti-blur tricks.
Time sync & georef best practices (camera trigger → GNSS timestamp → EXIF/XMP; PTP/pps if relevant).
Mission design patterns that worked in vineyards: corridor vs facade, altitude bands, gimbal angles, overlap for solid 3D.
Pointers to reference builds, repos, papers, or datasets specific to vineyards/orchards.
In short, I’m moving beyond DJI to an open stack so I can control perception + nav and get repeatable, low-altitude inspections with usable 3D. I’m confident on the ML/vision side—just need seasoned advice on approach + hardwareto start right.
Huge thanks for any experience you can share!
