Benewake Launches VLS-H5 LiDAR: Setting a New Perception Standard for High-End Pool Cleaners
While consumer robotics frequently make headlines with humanoid form factors and futuristic drones, a quieter revolution is taking place beneath the surface. Pool cleaning robots have quietly emerged as the most commercially mature and steady champions of the consumer robotics race. Today, Chinese solid-state LiDAR pioneer Benewake has unlocked the next generation of underwater mobility with the commercial launch of its VLS-H5—the world’s first mass-produced 360° underwater omnidirectional scanning LiDAR designed specifically to bring precise spatial awareness to extreme aquatic environments.
For years, underwater perception has remained a notorious challenge for hardware engineers. Unlike land-based robots, underwater platforms must grapple with intense sunlight reflections at the water’s surface, optical refraction from wave ripples, and severe signal scattering caused by organic debris. By launching the VLS-H5, Benewake directly addresses these physics-bound limitations, allowing pool cleaning robots to transition from blind, randomized scrubbing to highly precise, centimeter-level path planning.
First Commercial Adoption: The MOVA Rover X10
Demonstrating the immediate commercial viability of this technology, robotic innovator Surge Future has integrated the VLS-H5 into its newly unveiled flagship product: the MOVA Rover X10.
Equipped with enhanced vertical propulsion, the Rover X10 operates like an underwater drone, navigating autonomously along three axes—ascending, hovering, descending, and moving horizontally. Powered by Benewake’s LiDAR-driven SLAM algorithm, the Rover X10 abandons primitive boundary-following logic. Instead, it generates a comprehensive, real-time spatial map of complex pools, capturing curved steps, variable depths, and sharp corners with accuracy that easily outclasses traditional sonar or camera-only alternatives.
文章内容
Engineered for Extremes: Three Core Capabilities
The VLS-H5 is not a modified terrestrial sensor; it is a ground-up optical solution engineered specifically for harsh underwater environments:
160 KLux Light Immunity: Standard optical sensors suffer from receiver saturation when exposed to the intense midday sun in tropical or low-latitude markets, where ambient light routinely exceeds 100 KLux. The VLS-H5 handles up to 160 KLux of light exposure, maintaining stable point-cloud outputs even under direct, harsh summer sunlight.
Penetrating Water Turbidity: Using a Class 1 eye-safe visible light source, the sensor delivers a range of over 5 meters in clear water (covering up to 78 m² in a single scan). In highly turbid water (NTU ≤ 4), it consistently maintains a detection range of ≥1.5 meters with an accuracy margin of under 3 centimeters.
Compact and Hardened Architecture: Measuring just 75 × 52 × 53 mm, the sensor fits seamlessly into the tightly constrained 5-to-10 cm depth envelopes of modern robots. Rated IPX8, the VLS-H5 operates continuously at depths of up to 4 meters, protected by specialized anti-UV, anti-corrosion materials, and high-transmittance optical coatings.
Shifting from Passive Automated to Genuinely Intelligent Cleaning
The integration of the VLS-H5 changes how a pool robot interacts with its environment. Leveraging a 360-degree sweep at a 6 Hz refresh rate, the mapping process is nearly instantaneous. Users no longer have to wait for the robot to slowly trace every edge of the pool before generating a layout on their mobile app; instead, a complete, highly accurate map is rendered almost immediately.
Furthermore, the VLS-H5 keeps blind spots under 10 centimeters. By continuously monitoring distances to walls and obstacles, the robot dynamically plans paths around toys or structural elements, decelerating smoothly and cleaning tight edges without aggressive, structural-damaging collisions. If interrupted, the robot resumes its path with millimeter-level memory, avoiding repetitive cleaning and minimizing energy consumption.
Executive Perspectives
“We have established highly mature manufacturing and delivery pipelines for pool-robotic LiDAR systems,” said Dr. Yuan Li, CEO of Benewake. “The VLS-H5 underwater 360° omnidirectional scanner has officially achieved mass production with its debut on the MOVA series, and we look forward to rolling out more specialized sensors in the near future.”
“Our strategic partnership with Benewake marks a major leap forward in intelligent underwater perception,” noted Lei Huang, President of Surge Future & Global Head of MOVA. “Benewake’s robust LiDAR technology equips our robots with peerless spatial awareness. This collaboration allows us to deliver a faster, smarter, and entirely hands-free pool cleaning experience, pushing the boundaries of what consumers can expect.”
About Benewake
Benewake is a leading deep-tech company focused on “building the eyes for autonomous machines” and establishing the sensory infrastructure for physical AI. Founded and led by a distinguished executive team of PhDs—including CEO Dr. Yuan Li (alumnus of Wake Forest University, mentored by Dr. Xurong Xu, a pioneer of Chinese luminescence physics) and CTO Dr. Da Shu (alumnus of Université Paris-Saclay)—the company is bringing automotive-grade reliability to diverse robotics fields. Today, Benewake is one of the world’s leading suppliers of pool-cleaning LiDAR systems, driving high-performance spatial awareness across outdoor mowing, embodied AI, and global logistics networks.
