Dear all,
I have a question about altitude control using baro (without gps or sonar, lidar). I use postition_estimator_inav module and see a line of code as follows:
/* publish local position */
local_pos.xy_valid = can_estimate_xy;
local_pos.v_xy_valid = can_estimate_xy;
local_pos.xy_global = local_pos.xy_valid && use_gps_xy;
local_pos.z_global = local_pos.z_valid && use_gps_z;
local_pos.x = x_est[0];
local_pos.vx = x_est[1];
local_pos.y = y_est[0];
local_pos.vy = y_est[1];
local_pos.z = z_est[0];
local_pos.vz = z_est[1];
local_pos.yaw = att.yaw;
local_pos.dist_bottom_valid = dist_bottom_valid;
local_pos.eph = eph;
local_pos.epv = epv;
I think local_pos.z is the target height value calculated (or corrected) by barometer; however, when I extract this value using flightplot, the unit in the Y axis can be negative, so my question is what is the unit of this value ( I presume it should be in ‘meters’), why it can be negative?
Furthermore, is baro data converted into meters in the firmware?
Thanks.
Z points downward in the Local frame.
Baro altitude is published in meters in the sensor_combined topic.
Beware that baro altitude is AMSL (above mean sea level) so it will be positive unless you’re on the ground in New Orleans
Thanks for the reply. As you have said, I can understand Z could be negative since it represents AMSL, and points downward in the axis. My question then is how the base point, I mean, (0,0,0) is determined? Z value only makes sense when there exists a base point, am I right?
The 0 point is calculated as the average of first several hundreds of barometer values.
If you search “wait_baro” in the cpp file, you will find more details.
Hope this correct.
Thanks for the quick reply.
Yeah, I see wait_baro variable in the file, and I also understand the calculation of average baro values, but I do not see any evidence that says this average value is regarded as the 0 point in the axis. This value, I think, is the initial value before flight, or precisely speaking, before the copter is armed. Any ideas?
This average is stored in baro_offset.
When the baro is used, this would be subtracted from the barometer value.
corr_baro = baro_offset - sensor.baro_alt_meter - z_est[0];
Isn’t it?
Oh, you are right. Zero Z is regarded as the baro_offset point, but the actual baro_offset value is not 0; it is the AMSL value, and z_est[0] is the actual flight height in meters. Am I right?
The z_est in the inav module should be regarded as the height w.r.t where you start the system, no matter how the ground changes during the flight.
