Hello all,
Depending on this implementation https://github.com/ArduPilot/ardupilot/pull/13839 (pending to be merged for Copter), I have a task to adjust QGroundControl to be able to show the boats on the map as the Copter is moving (the AIS will be mounted on the plane). I have read this documentation AIS (for boats) — Rover documentation, but it is for rover for now. I should just use the ADSB stream rate (SRx_ADSB) and the boats will appear like in documentation or are there more steps to follow?
Thank you in advance
