Is there any support for allowing an adsb transceiver to transmit a fixed wing’s location to other aircraft. Right now, I am only able to see other planes in the area, but I can’t transmit my own planes location. I’m using qgc to view the aircraft and then using a separate application to see other aircraft in the area. My fixed wing isnt transmitting any information at all from what can be seen on the other application.
Hi
Please can you advice what are the parameters you configured to see the ADSB values in your transmitter.
thank you
