Hello
I was using jmavsim and it worked perfectly fine. Then i once tried to run it with sudo (I cant remember why). After that it didn’t work anymore and the console shows the following output. Is there anything I can do to fix this, or do I have to reinstall my Ubuntu (last option).
[0/1] cd /home/aurel/Documents/Focusproject/Code/PX4-Autopilot/build/px4_sitl_default/tmp && /home/aurel/D...cusproject/Code/PX4-Autopilot /home/aurel/Documents/Focusproject/Code/PX4-Autopilot/build/px4_sitl_default
SITL ARGS
sitl_bin: /home/aurel/Documents/Focusproject/Code/PX4-Autopilot/build/px4_sitl_default/bin/px4
debugger: none
program: jmavsim
model: none
world: none
src_path: /home/aurel/Documents/Focusproject/Code/PX4-Autopilot
build_path: /home/aurel/Documents/Focusproject/Code/PX4-Autopilot/build/px4_sitl_default
SITL COMMAND: "/home/aurel/Documents/Focusproject/Code/PX4-Autopilot/build/px4_sitl_default/bin/px4" "/home/aurel/Documents/Focusproject/Code/PX4-Autopilot/build/px4_sitl_default"/etc -s etc/init.d-posix/rcS -t "/home/aurel/Documents/Focusproject/Code/PX4-Autopilot"/test_data
Creating symlink /home/aurel/Documents/Focusproject/Code/PX4-Autopilot/build/px4_sitl_default/etc -> /home/aurel/Docume
ERROR [px4_daemon] error binding socket /tmp/px4-sock-0, error = Address already in use
______ __ __ ___
| ___ \ \ \ / / / |
| |_/ / \ V / / /| |
| __/ / \ / /_| |
| | / /^\ \ \___ |
\_| \/ \/ |_/
px4 starting.
INFO [init] found model autostart file as SYS_AUTOSTART=10016
ERROR [px4_daemon] error connecting to socket: Permission denied
[param] parameter file not found, creating eeprom/parameters_10016
Error: no autostart file found (/home/aurel/Documents/Focusproject/Code/PX4-Autopilot/build/px4_sitl_default/tmp/rootfs/etc/init.d-posix/airframes/ERROR [px4_daemon] error connecting to socket: Permission denied_*)
ERROR [px4] Startup script returned with return value: 256
Thanks for helping!
