In rare cases after arming throttle level is higher for a second, then goes back to normal values.
I noticed it first time when I used 1.7 firmware, however there is similar topic from previous year Slight higher idle throttle when first arm? .
Hopefully I have a log https://logs.px4.io/plot_app?log=7c0b159c-bf28-48dc-8677-b3ccd1c2d25b .
I’d ask someone to check the log because I want to be sure that copter can’t apply too much throttle on startup.
In related issue was mentioned that MPC_THR_MIN could affect but after I lowered the parameter nothing has changed.
Maybe I will fill the bug in Github shortly.
Did you find a solution to this problem?
Sort of: switched back to Ardupilot.
Here is the (closed) issue: https://github.com/PX4/PX4-Autopilot/issues/9022
What do you mean? That you did not solve it and therefore you switched to Ardupilot?
