Hello! I am having an issue with a custom VTOL airframe, it is failing to transition to fixed wing due to not meeting the transition minimum airspeed. I have swapped our airspeed sensor and re-calibrated multiple times. I will attach a ulg of our recent failed flight as well as the current parameter configuration. Any suggestions/advice would be appreciated!
Hi Derek,
Welcome to the PX4 community!
I had an initial look at your Flight Review summary.
Your aircraft is running PX4 1.16 on an ARK FMU V6X, using the Standard VTOL configuration.
One interesting observation is that the flight summary reports a maximum horizontal groundspeed of approximately 27.3 m/s.
However, this does not necessarily mean the aircraft reached the required transition airspeed. We need to check when that speed occurred and compare the measured airspeed with the transition threshold.
Since you have already replaced and recalibrated the airspeed sensor, I would investigate the transition sequence before assuming another sensor failure.
I suggest checking:
Airspeed versus transition threshold
Compare the measured airspeed against
VT_ARSP_TRANSthroughout the front transition. -
Forward motor thrust
Check whether the pusher motor reaches the commanded transition throttle (
VT_F_TRANS_THR) and whether the aircraft accelerates as expected. -
Transition timing
Examine
VT_F_TR_OL_TM,VT_TRANS_TIMEOUT, and the exact event that terminates the transition. -
Pitch attitude
Check whether excessive nose-up attitude or insufficient forward acceleration prevents the aircraft from reaching the required airspeed.
Airspeed measurement
Compare airspeed, groundspeed, and estimated wind during the transition. Also verify pitot orientation, tubing, and possible propeller-wash interference.
Could you confirm:
Your configured
VT_ARSP_TRANSvalue? -
Your
VT_F_TRANS_THRsetting? -
Whether the forward motor reaches its expected output?
Whether the vehicle aborts the transition automatically or simply remains in transition mode?
The aircraft’s approximate stall speed and VTOL configuration?
I would be particularly interested in identifying the first point where expected and actual transition behavior diverge.
I would avoid reducing the transition airspeed threshold without first confirming that the aircraft has sufficient margin above its stall speed.
With the transition-specific airspeed, attitude, thrust, and mode data, we should be able to narrow this down considerably.
Best regards,
Yiğitcan Öztürk
PAMILANGA LIMITED
Adding to what Yigitcan said: if ground speed hit about 27 m/s but the airspeed never reached VT_ARSP_TRANS, I’d look at airspeed scaling before suspecting the sensor again. Plot airspeed_validated against ground speed in the log. A pitot tube sitting in the prop wash or close to the fuselage boundary layer, or a bad tube or line, can read low no matter how many times it’s recalibrated. Also check that VT_F_TRANS_THR gives the pusher enough thrust and that VT_TRANS_TIMEOUT isn’t aborting the transition too early. As a temporary test you could lower VT_ARSP_TRANS slightly, keeping it safely above stall, to confirm the diagnosis. Where is the pitot mounted on your airframe?
Hi yi_yong_li,
Thanks for adding these points. I agree that airspeed measurement quality and pitot installation deserve closer attention, particularly since the sensor has already been replaced and recalibrated.
One distinction worth keeping in mind is that the reported maximum groundspeed may have occurred outside the front-transition interval.
I would suggest aligning the following signals on the same timeline:
Validated airspeed and its validity status
Groundspeed and estimated wind
VTOL transition state and relevant vehicle status
Pusher motor command and actual output, where available
Pitch attitude and transition-related events
This should help distinguish between insufficient forward acceleration, unreliable airspeed measurement, and a transition timeout or abort.
I would also be cautious about lowering VT_ARSP_TRANS as a diagnostic step before confirming the aircraft’s stall-speed margin and the cause of the failed transition.
Derek, could you share the pitot tube mounting location and the configured transition parameters?
If the relevant ULog is available, we could focus on the exact front-transition interval and identify where the expected and measured behavior first diverge.
Best regards,
Yiğitcan Öztürk
PAMILANGA LIMITED
