VTOL and Gas engine with USB-Joystick
Hello, I am wondering is it is possible to fly VTOLs with USB Joysticks. I have issues to set the Transition switch. If I am right there is a need to have a Trans_Switch for vtols. that is not possible with USB JOystick.
The same is when I use a Gas engine, there I need a AUX Channel Passthrough for Enable or Disable the KillSwitch for the eninge.
Did someone made some expierences?
