I am working in ROS2 Humble on Ubuntu 22.04.3 LTS. I’m using QGroundControl Daily Version, and I’m launching jmavsim from the PX4-Autopilot (commit 54d26e084a).
I have a set of ros2 scripts that I’m using to control the drone in the simulation, but the vehicle_local_position topic seems to be acting strange.
I launch QGroundControl, then I launch jmavsim. QGC recognizes and “connects” to the jmavsim drone fine.
I run MicroXRCEAgent udp4 -p 8888.
When I go into my ros2 workspace, i run source install/setup.bash, and then I can see the px4 ros2 topics if I run ros2 topic list.
As far as I can tell I’m getting good data from all the topics except for the vehicle_local_position one. If I type ros2 topic echo /fmu/out/vehicle_global_position, the output looks normal/fine. However, if I type ros2 topic echo /fmu/out/vehicle_local_position, this is the output (repeated):
2023-11-06 09:14:49.700 [RTPS_READER_HISTORY Error] Change payload size of '196' bytes is larger than the history payload size of '191' bytes and cannot be resized. -> Function can_change_be_added_nts
Any ideas what the issue could be? Ultimately, the local position subscriber on my node isn’t getting the local position, probably because of this error.
