I am trying to connect PX4 (v1.14) via ROS2 (Foxy on ubuntu 20.04) with uxrce_dds_client as described in
My set up is
[PX4-6X module <–dev/ttyS3–> VOXL(ROS2 foxy, ubuntu 18.04)] ← Ethernet → [Hub] ← Ethernet → [Host PC (ROS2 foxy, ubuntu 20.04)]
I was successfully run $ ros2 launch px4_offboard offboard_position_control.launch.py
on my host PC.
Only issue right now is that uxrce_dds_client
can only run when mavlink stop-all
commanded in nsh.
I tried to set MAV_1_CONFIG which was assigned to /dev/ttyS3 as ‘Disabled’ but no luck.
mavlink stop #1
did not work either.
uxrce_dds_client only works when all mavlink instances are stopped by mavlink stop-all
command.
Is this known issue or I am doing it wrong?
Thanks for any help.
Kyu
