I am running PX4 release/1.14 on 6X module.
When checked the status of uxrce_dds_client, I noticed FILLED indicating 93.1%!
Is this normal? What is causing this large amount of FILLED?
nsh> ps
PID GROUP PRI POLICY TYPE NPX STATE EVENT SIGMASK STACK USED FILLED COMMAND
0 0 0 FIFO Kthread N-- Ready 00000000 000726 000476 65.5% Idle Task
1 1 249 FIFO Kthread --- Waiting Semaphore 00000000 001224 000292 23.8% hpwork 0x24000ac0
2 2 50 FIFO Kthread --- Waiting Semaphore 00000000 001576 000860 54.5% lpwork 0x24000ad4
3 3 100 FIFO Task --- Waiting Semaphore 00000000 002896 002164 74.7% nsh_main
4 4 255 FIFO Task --- Waiting Semaphore 00000000 001232 000548 44.4% wq:manager
5 5 100 FIFO Task --- Waiting Semaphore 00000000 001984 000556 28.0% Telnet daemon 0x38008fd0
6 3 49 FIFO pthread --- Waiting Semaphore 00000000 002024 000780 38.5% netinit 0
1865 1865 100 FIFO Task --- Waiting Signal 00000000 003144 001996 63.4% mavlink_if3 mavlink start -d /dev/ttyACM0
522 4 251 FIFO pthread --- Waiting Semaphore 00000000 002368 001384 58.4% wq:SPI3 0x81ef424
587 4 253 FIFO pthread --- Waiting Semaphore 00000000 002368 001696 71.6% wq:SPI1 0x81ef414
1868 1865 175 FIFO pthread --- Waiting Semaphore 00000000 005976 002692 45.0% mavlink_rcv_if3 0x30028608
1869 1869 100 FIFO Task --- Running 00000000 002000 001484 74.2% mavlink_shell
1486 1461 175 FIFO pthread --- Waiting Semaphore 00000000 005976 002292 38.3% mavlink_rcv_if2 0x30017ce8
591 4 243 FIFO pthread --- Waiting Semaphore 00000000 002312 000960 41.5% wq:I2C4 0x81ef3e4
1872 1869 49 FIFO pthread --- Waiting Semaphore 00000000 002024 000692 34.1% netinit 0
1233 1233 100 FIFO Task --- Waiting Signal 00000000 003048 001980 64.9% mavlink_if0 mavlink start -d /dev/ttyS6 -b p:SER_TEL1_BAUD -m p:MAV_0_MODE -r p:MAV_0_RATE -f -s -x
1234 1233 175 FIFO pthread --- Waiting Semaphore 00000000 005976 002292 38.3% mavlink_rcv_if0 0x3000e488
1043 1043 205 FIFO Task --- Waiting Semaphore 00000000 001936 001236 63.8% gps start -d /dev/ttyS0 -b p:SER_GPS1_BAUD
1813 1813 105 FIFO Task --- Waiting Semaphore 00000000 001896 001032 54.4% navigator start
1302 1302 100 FIFO Task --- Waiting Signal 00000000 003056 001980 64.7% mavlink_if1 mavlink start -d /dev/ttyS4 -b p:SER_TEL2_BAUD -m p:MAV_1_MODE -r p:MAV_1_RATE -s -x
1303 1302 175 FIFO pthread --- Waiting Semaphore 00000000 005976 002292 38.3% mavlink_rcv_if1 0x30013238
600 600 100 FIFO Task --- Waiting Signal 00000000 009880 009204 93.1%! uxrce_dds_client start -t serial -d /dev/ttyS3 -b 921600
729 4 242 FIFO pthread --- Waiting Semaphore 00000000 002216 001196 53.9% wq:nav_and_controllers 0x81aa544
730 4 255 FIFO pthread --- Waiting Semaphore 00000000 003120 002308 73.9% wq:rate_ctrl 0x81dfc74
732 4 241 FIFO pthread --- Waiting Semaphore 00000000 005976 004316 72.2% wq:INS0 0x81ef3ec
478 4 246 FIFO pthread --- Waiting Semaphore 00000000 002312 001024 44.2% wq:I2C1 0x81ef3cc
231 4 237 FIFO pthread --- Waiting Semaphore 00000000 001872 000888 47.4% wq:hp_default 0x819bc4c
744 4 240 FIFO pthread --- Waiting Semaphore 00000000 005976 004316 72.2% wq:INS1 0x81ef3f4
489 4 245 FIFO pthread --- Waiting Semaphore 00000000 002312 000840 36.3% wq:I2C2 0x81ef3d4
556 4 252 FIFO pthread --- Waiting Semaphore 00000000 002368 001964 82.9%! wq:SPI2 0x81ef41c
749 4 239 FIFO pthread --- Waiting Semaphore 00000000 005976 004316 72.2% wq:INS2 0x81ef3fc
752 752 140 FIFO Task --- Waiting Signal 00000000 003192 001492 46.7% commander start
1461 1461 100 FIFO Task --- Waiting Signal 00000000 003048 001836 60.2% mavlink_if2 mavlink start -u p:MAV_2_UDP_PRT -o p:MAV_2_REMOTE_PRT -m p:MAV_2_MODE -r p:MAV_2_RATE -p -x
1847 1847 230 FIFO Task --- Waiting Semaphore 00000000 003616 002532 70.0% logger start -b 64 -t
1850 1847 60 FIFO pthread --- Waiting Semaphore 00000000 001144 000388 33.9% log_writer_file 0x30016cc0
443 4 229 FIFO pthread --- Waiting Semaphore 00000000 001704 001108 65.0% wq:ttyS5 0x81ef46c
381 381 90 FIFO Task --- Waiting Semaphore 00000000 001280 000852 66.5% dataman
1854 4 236 FIFO pthread --- Waiting Semaphore 00000000 003600 002244 62.3% wq:uavcan 0x819d2dc
383 4 205 FIFO pthread --- Waiting Semaphore 00000000 001896 001028 54.2% wq:lp_default 0x81a1880
Also for the client status, why it is not receiving any packets?
Is this something makes FILLED up to 93% of buffer?
nsh> uxrce_dds_client status
INFO [uxrce_dds_client] Running, connected
INFO [uxrce_dds_client] Using transport: serial
INFO [uxrce_dds_client] Payload tx: 51743 B/s
INFO [uxrce_dds_client] Payload rx: 0 B/s
