I am running a serial connection between a Pixhawk 4 and a Raspberry Pi. For some reason the client doesn’t start automatically when the pixhawk turns on but when I start it manually it posts the following errors stating that it couldnt create the topics.
Any help is appreciated.
Additional log showing that it connects initially, then shuts itself down. Upon restarting the errors appear.
nsh> uxrce_dds_client status
INFO [uxrce_dds_client] Running, disconnected
INFO [uxrce_dds_client] Using transport: serial
INFO [uxrce_dds_client] Running, connected
INFO [uxrce_dds_client] Payload tx: 0 B/s
INFO [uxrce_dds_client] Payload rx: 0 B/s
INFO [uxrce_dds_client] not running
nsh> uxrce_dds_client start -t serial -d /dev/ttyS2 -b 921600
nsh> ERROR [uxrce_dds_client] create entities failed: rt/fmu/in/offboard_control_mode 255 255 255
ERROR [uxrce_dds_client] create entities failed: rt/fmu/in/onboard_computer_status 255 255 255
ERROR [uxrce_dds_client] create entities failed: rt/fmu/in/obstacle_distance 255 255 255
ERROR [uxrce_dds_client] create entities failed: rt/fmu/in/sensor_optical_flow 255 255 255
ERROR [uxrce_dds_client] create entities failed: rt/fmu/in/telemetry_status 255 255 255
ERROR [uxrce_dds_client] create entities failed: rt/fmu/in/trajectory_setpoint 255 255 255
ERROR [uxrce_dds_client] create entities failed: rt/fmu/in/vehicle_attitude_setpoint 255 255 255
ERROR [uxrce_dds_client] create entities failed: rt/fmu/in/vehicle_mocap_odometry 255 255 255
ERROR [uxrce_dds_client] create entities failed: rt/fmu/in/vehicle_rates_setpoint 255 255 255
ERROR [uxrce_dds_client] create entities failed: rt/fmu/in/vehicle_visual_odometry 255 255 255
ERROR [uxrce_dds_client] create entities failed: rt/fmu/in/vehicle_command 255 255 255
ERROR [uxrce_dds_client] create entities failed: rt/fmu/in/vehicle_trajectory_bezier 255 255 255
ERROR [uxrce_dds_client] create entities failed: rt/fmu/in/vehicle_trajectory_waypoint 255 255 255
INFO [uxrce_dds_client] synchronized with time offset 0 us
ERROR [uxrce_dds_client] create entities failed: rt/fmu/out/failsafe_flags, topic: 255 publisher: 255 datawriter: 255
ERROR [uxrce_dds_client] create entities failed: rt/fmu/out/position_setpoint_triplet, topic: 255 publisher: 255 datawriter: 2
ERROR [uxrce_dds_client] create entities failed: rt/fmu/out/sensor_combined, topic: 255 publisher: 255 datawriter: 255
ERROR [uxrce_dds_client] create entities failed: rt/fmu/out/timesync_status, topic: 255 publisher: 255 datawriter: 255
ERROR [uxrce_dds_client] create entities failed: rt/fmu/out/vehicle_attitude, topic: 255 publisher: 255 datawriter: 255
ERROR [uxrce_dds_client] create entities failed: rt/fmu/out/vehicle_control_mode, topic: 255 publisher: 255 datawriter: 255
ERROR [uxrce_dds_client] create entities failed: rt/fmu/out/vehicle_gps_position, topic: 255 publisher: 255 datawriter: 255
ERROR [uxrce_dds_client] create entities failed: rt/fmu/out/vehicle_local_position, topic: 255 publisher: 255 datawriter: 255
ERROR [uxrce_dds_client] create entities failed: rt/fmu/out/vehicle_odometry, topic: 255 publisher: 255 datawriter: 255
ERROR [uxrce_dds_client] create entities failed: rt/fmu/out/vehicle_status, topic: 255 publisher: 255 datawriter: 255
INFO [uxrce_dds_client] No ping response, disconnecting
WARN [timesync] RTT too high for timesync: 117 ms
WARN [timesync] RTT too high for timesync: 28 ms
INFO [uxrce_dds_client] synchronized with time offset 1708544696465800us
INFO [uxrce_dds_client] synchronized with time offset 1708544696465777us
INFO [uxrce_dds_client] synchronized with time offset 1708544696465747us
WARN [timesync] RTT too high for timesync: 114 ms
WARN [timesync] RTT too high for timesync: 116 ms
INFO [uxrce_dds_client] synchronized with time offset 1708544696465667us
ERROR [uxrce_dds_client] create entities failed: participant: 255
WARN [timesync] RTT too high for timesync: 107 ms
WARN [timesync] RTT too high for timesync: 108 ms
INFO [uxrce_dds_client] synchronized with time offset 1708544696461776us
