Hey all,
When developing a plugin I use qDebug() to output debug information. However, in some cases qDebug() doesn’t appear to actually work.
The example here is the adjustIncomingMavlinkMessage() function in the CustomFirmwarePlugin - for some reason none of the debug logs run inside this or it’s sister function.
The constructor for the CustomFirmwarePlugin does run, so from what I understand this above function should be called by the system when MavLink messages arrive from the connected vehicle. There is a BlueROV connected to the system when built.
So is there a reason that qDebug() won’t log from certain functions like this one? Or is it indicative of some other issue with my setup - ie is the function not actually being called?
Thanks for your help!
