I am having trouble saving any parameters to my Pixhawk (none of them survive a reboot). I have been digging in the code to understand what is supposed to happen, but I am afraid I’ll need some help to solve this.
I have tried this:
Setting from QGC console:
Setting the airframe, selecting “apply”, then “apply and restart”. After boot, the parameter is still 0.
Setting from mavlink console:
nsh> param set SYS_AUTOSTART 7001 SYS_AUTOSTART: curr: 0 -> new: 7001 nsh> param save
After restart, the value is still 0
Background:
- I have flashed developer build from QGC (I get the same problem with other builds)
- SD card seems to be working “ls /fs/microsd/” correctly lists the contents, and I can both create files and read them from a computer (with microsd adapter)
- I have only the debug console connected at the moment.
- During boot, I get an error from the parameter importer, see boot log below
- I have got the toolchain set up and I am a fw developer myself, so please let me know if you have an idea on how to debug this from with code.
- If I export parameters using “param save /fs/microsd/out.txt”, I only get a seemingly incomplete file containing only one line:
" _V_VOLT "
Bootlog (over system console)
[boot] Fault Log info File No 3 Length 3257 flags:0x01 state:1 [boot] Fault Log is Armed sercon: Registering CDC/ACM serial driver sercon: Successfully registered the CDC/ACM serial driver [i] microSD mounted: /fs/microsd [hardfault_log] Fault Log is Armed INFO [param] selected parameter default file /fs/mtd_params ERROR [param] importing from '/fs/mtd_params' failed (-1) rgbled on I2C bus 2 at 0x55 (bus: 100 KHz, max: 100 KHz) BAT_N_CELLS: curr: 0 -> new: 3 INFO [dataman] Unkown restart, data manager file '/fs/microsd/dataman' size is 361560 bytes MS5611_SPI on SPI bus 4 at 2 (20000 KHz) WARN [ms5611] no device on bus 4 MS5611_SPI on SPI bus 1 at 3 (20000 KHz) WARN [bst] no devices found INFO [ver] match: PX4FMU_V2 WARN [hmc5883] no device on bus 1 (type: 2) WARN [lis3mdl] no device on bus 2 WARN [hmc5883] no device on bus 2 (type: 1) WARN [mpu6000] no device on bus 5 WARN [mpu9250] probe failed! 255 WARN [mpu9250] no device on bus 4 MPU6000 on SPI bus 1 at 4 (1000 KHz) WARN [mpu6000] no device on bus 5 WARN [mpu9250] probe failed! 104 WARN [mpu9250] no device on bus 3 WARN [mpu9250] probe failed! 255 WARN [mpu9250] no device on bus 4 L3GD20 on SPI bus 1 at 1 (11000 KHz) LSM303D on SPI bus 1 at 2 (11000 KHz) ERROR [sdp3x_airspeed] reset failed WARN [sdp3x_airspeed] trying SDP3X 2 ERROR [sdp3x_airspeed] reset failed WARN [sdp3x_airspeed] SDP3X init fail WARN [sdp3x_airspeed] no SDP3X airspeed sensor connected ERROR [meas_airspeed] no MS4525 airspeed sensor connected ERROR [ets_airspeed] no ETS airspeed sensor connected ERROR [ets_airspeed] no ETS airspeed sensor connected INFO [load_mon] stack check enabled ERROR [param] Parameter UAVCAN_ENABLE not found INFO [px4io] default PWM output device INFO [mavlink] mode: Normal, data rate: 1200 B/s on /dev/ttyS1 @ 57600B INFO [mavlink] mode: OSD, data rate: 1000 B/s on /dev/ttyS2 @ 57600B ERROR [param] Parameter UAVCAN_ENABLE not found INFO [ver] match: PX4FMU_V2 px4flow [156:100] WARN [px4flow] scanning I2C buses for device.. INFO [mavlink] mode: Config, data rate: 800000 B/s on /dev/ttyACM0 @ 57600B INFO [logger] logger started (mode=all) No autostart ID found NuttShell (NSH) nsh>
