@Benja Thank you for your reply, I will try it later
Had the same prob. This worked for me.
Ubuntu 20.0.4.
Hi ! ALL
Could U help me please
My Ubuntu
Distrib.pdf (491 Bytes)
My PX4 process installation with ubuntu.sh
PX4_installation.pdf (300.1 KB)
and try to make gazebo simulation— have error
ninja: error: unknown target ‘sitl_gazebo-classic’
make: *** [Makefile:227: px4_sitl_default] Error 1
make gazebo-classic.pdf (7.7 KB)
I feel like you guys have the new gazebo installed and are trying to run the classic version. Try running this command first, to remove the new gazebo and download the classic one:
sudo apt remove gz-garden
sudo apt install aptitude
sudo aptitude install gazebo libgazebo11 libgazebo-dev
Hi guys, newbie here. I have ubuntu 22.0 and I installed gazebo classic but when I enter:
make px4_sitl gazebo-classic
it ends with:
T_BIND_GLOBAL_PLACEHOLDERS to retain the current behavior.’
36 | BOOST_PRAGMA_MESSAGE(
[142/142] Linking CXX shared library libgazebo_user_camera_plugin.so
[980/981] cd /home/emiliano/PX4-Autopilot/build/px4_sitl_de...topilot /home/emiliano/PX4-Autopilot/build/px4_sitl_default
SITL ARGS
sitl_bin: /home/emiliano/PX4-Autopilot/build/px4_sitl_default/bin/px4
debugger: none
model: iris
world: none
src_path: /home/emiliano/PX4-Autopilot
build_path: /home/emiliano/PX4-Autopilot/build/px4_sitl_default
You need to have gazebo simulator installed!
FAILED: src/modules/simulation/simulator_mavlink/CMakeFiles/gazebo-classic_iris /home/emiliano/PX4-Autopilot/build/px4_sitl_default/src/modules/simulation/simulator_mavlink/CMakeFiles/gazebo-classic_iris
cd /home/emiliano/PX4-Autopilot/build/px4_sitl_default/src/modules/simulation/simulator_mavlink && /home/emiliano/PX4-Autopilot/Tools/simulation/gazebo-classic/sitl_run
btw, I already used the sequence
do I have hope with ubuntu 22 or shall I downgrade to Ubuntu 20?
I think the path you chose to install the Gazebo may be incorrect. It simply cannot find the gazebo simulation app.
Hi @Benja I am having the same problem. Please find the ubuntu.sh code below.
FYI I am using Ubuntu 22.04 with ROS2 packages installed and Gazebo Sim 7.
Code:
#! /usr/bin/env bash
set -e
Bash script to setup PX4 development environment on Ubuntu LTS (22.04, 20.04, 18.04).
Can also be used in docker.
Installs:
- Common dependencies and tools for nuttx, jMAVSim, Gazebo
- NuttX toolchain (omit with arg: --no-nuttx)
- jMAVSim and Gazebo9 simulator (omit with arg: --no-sim-tools)
INSTALL_NUTTX=“true”
INSTALL_SIM=“true”
INSTALL_ARCH=uname -m
Parse arguments
for arg in “$@”
do
if [[ $arg == “–no-nuttx” ]]; then
INSTALL_NUTTX=“false”
fi
if [[ $arg == "--no-sim-tools" ]]; then
INSTALL_SIM="false"
fi
done
detect if running in docker
if [ -f /.dockerenv ]; then
echo “Running within docker, installing initial dependencies”;
apt-get --quiet -y update && DEBIAN_FRONTEND=noninteractive apt-get --quiet -y install
ca-certificates
gnupg
lsb-core
sudo
wget
fi
script directory
DIR=$( cd “$( dirname “${BASH_SOURCE[0]}” )” && pwd )
check requirements.txt exists (script not run in source tree)
REQUIREMENTS_FILE=“requirements.txt”
if [[ ! -f “${DIR}/${REQUIREMENTS_FILE}” ]]; then
echo “FAILED: ${REQUIREMENTS_FILE} needed in same directory as ubuntu.sh (${DIR}).”
return 1
fi
check ubuntu version
otherwise warn and point to docker?
UBUNTU_RELEASE=“lsb_release -rs”
if [[ “${UBUNTU_RELEASE}” == “14.04” ]]; then
echo “Ubuntu 14.04 is no longer supported”
exit 1
elif [[ “${UBUNTU_RELEASE}” == “16.04” ]]; then
echo “Ubuntu 16.04 is no longer supported”
exit 1
elif [[ “${UBUNTU_RELEASE}” == “18.04” ]]; then
echo “Ubuntu 18.04”
elif [[ “${UBUNTU_RELEASE}” == “20.04” ]]; then
echo “Ubuntu 20.04”
elif [[ “${UBUNTU_RELEASE}” == “22.04” ]]; then
echo “Ubuntu 22.04”
fi
echo
echo “Installing PX4 general dependencies”
sudo apt-get update -y --quiet
sudo DEBIAN_FRONTEND=noninteractive apt-get -y --quiet --no-install-recommends install
astyle
build-essential
cmake
cppcheck
file
g++
gcc
gdb
git
lcov
libfuse2
libxml2-dev
libxml2-utils
make
ninja-build
python3
python3-dev
python3-pip
python3-setuptools
python3-wheel
rsync
shellcheck
unzip
zip
Python3 dependencies
echo
echo “Installing PX4 Python3 dependencies”
if [ -n “$VIRTUAL_ENV” ]; then
# virtual environments don’t allow --user option
python -m pip install -r ${DIR}/requirements.txt
else
# older versions of Ubuntu require --user option
python3 -m pip install --user -r ${DIR}/requirements.txt
fi
NuttX toolchain (arm-none-eabi-gcc)
if [[ $INSTALL_NUTTX == “true” ]]; then
echo
echo "Installing NuttX dependencies"
sudo DEBIAN_FRONTEND=noninteractive apt-get -y --quiet --no-install-recommends install \
automake \
binutils-dev \
bison \
build-essential \
flex \
g++-multilib \
gcc-multilib \
gdb-multiarch \
genromfs \
gettext \
gperf \
libelf-dev \
libexpat-dev \
libgmp-dev \
libisl-dev \
libmpc-dev \
libmpfr-dev \
libncurses5 \
libncurses5-dev \
libncursesw5-dev \
libtool \
pkg-config \
screen \
texinfo \
u-boot-tools \
util-linux \
vim-common \
if [[ "${UBUNTU_RELEASE}" == "20.04" || "${UBUNTU_RELEASE}" == "22.04" ]]; then
kconfig-frontends \
fi
if [ -n "$USER" ]; then
# add user to dialout group (serial port access)
sudo usermod -aG dialout $USER
fi
# arm-none-eabi-gcc
NUTTX_GCC_VERSION="9-2020-q2-update"
NUTTX_GCC_VERSION_SHORT="9-2020q2"
source $HOME/.profile # load changed path for the case the script is reran before relogin
if [ $(which arm-none-eabi-gcc) ]; then
GCC_VER_STR=$(arm-none-eabi-gcc --version)
GCC_FOUND_VER=$(echo $GCC_VER_STR | grep -c "${NUTTX_GCC_VERSION}" || true)
fi
if [[ "$GCC_FOUND_VER" == "1" ]]; then
echo "arm-none-eabi-gcc-${NUTTX_GCC_VERSION} found, skipping installation"
else
echo "Installing arm-none-eabi-gcc-${NUTTX_GCC_VERSION}";
wget -O /tmp/gcc-arm-none-eabi-${NUTTX_GCC_VERSION}-linux.tar.bz2 https://armkeil.blob.core.windows.net/developer/Files/downloads/gnu-rm/${NUTTX_GCC_VERSION_SHORT}/gcc-arm-none-eabi-${NUTTX_GCC_VERSION}-${INSTALL_ARCH}-linux.tar.bz2 && \
sudo tar -jxf /tmp/gcc-arm-none-eabi-${NUTTX_GCC_VERSION}-linux.tar.bz2 -C /opt/;
# add arm-none-eabi-gcc to user's PATH
exportline="export PATH=/opt/gcc-arm-none-eabi-${NUTTX_GCC_VERSION}/bin:\$PATH"
if grep -Fxq "$exportline" $HOME/.profile; then
echo "${NUTTX_GCC_VERSION} path already set.";
else
echo $exportline >> $HOME/.profile;
source $HOME/.profile; # Allows to directly build NuttX targets in the same terminal
fi
fi
fi
Simulation tools
if [[ $INSTALL_SIM == “true” ]]; then
echo
echo "Installing PX4 simulation dependencies"
# General simulation dependencies
bc \
if [[ "${UBUNTU_RELEASE}" == "18.04" ]]; then
java_version=11
elif [[ "${UBUNTU_RELEASE}" == "20.04" ]]; then
java_version=13
elif [[ "${UBUNTU_RELEASE}" == "22.04" ]]; then
java_version=11
else
java_version=14
fi
# Java (jmavsim)
ant \
openjdk-$java_version-jre \
openjdk-$java_version-jdk \
libvecmath-java \
# Set Java 11 as default
sudo update-alternatives --set java $(update-alternatives --list java | grep "java-$java_version")
# Gazebo / Gazebo classic installation
echo "Gazebo (Garden) will be installed"
echo "Earlier versions will be removed"
# Add Gazebo binary repository
sudo wget https://packages.osrfoundation.org/gazebo.gpg -O /usr/share/keyrings/pkgs-osrf-archive-keyring.gpg
echo "deb [arch=$(dpkg --print-architecture) signed-by=/usr/share/keyrings/pkgs-osrf-archive-keyring.gpg] http://packages.osrfoundation.org/gazebo/ubuntu-stable $(lsb_release -cs) main" | sudo tee /etc/apt/sources.list.d/gazebo-stable.list > /dev/null
# Install Gazebo
gazebo_packages="gz-garden"
else
sudo sh -c 'echo "deb http://packages.osrfoundation.org/gazebo/ubuntu-stable `lsb_release -cs` main" > /etc/apt/sources.list.d/gazebo-stable.list'
wget http://packages.osrfoundation.org/gazebo.key -O - | sudo apt-key add -
# Update list, since new gazebo-stable.list has been added
# Install Gazebo classic
gazebo_classic_version=9
gazebo_packages="gazebo$gazebo_classic_version libgazebo$gazebo_classic_version-dev"
else
# default and Ubuntu 20.04
gazebo_classic_version=11
fi
fi
dmidecode \
$gazebo_packages \
gstreamer1.0-plugins-bad \
gstreamer1.0-plugins-base \
gstreamer1.0-plugins-good \
gstreamer1.0-plugins-ugly \
gstreamer1.0-libav \
libeigen3-dev \
libgstreamer-plugins-base1.0-dev \
libimage-exiftool-perl \
libopencv-dev \
libxml2-utils \
pkg-config \
protobuf-compiler \
if sudo dmidecode -t system | grep -q "Manufacturer: VMware, Inc." ; then
# fix VMWare 3D graphics acceleration for gazebo
echo "export SVGA_VGPU10=0" >> ~/.profile
fi
fi
echo
echo “Relogin or reboot computer before attempting to build NuttX targets”
fi
Further if you are on v1.13.0 of PX4 then use
Consult this Gazebo Simulation | PX4 User Guide (v1.13)
For those experiencing this issue Ubuntu 22.04 and using gazebo harmonic or garden, try this command instead
make px4_sitl gz_x500
PX4 Gazebo Simulation
I got the same problem I solved by
make px4_sitl gazebo I am using ubuntu 20.04 LTS , px4 V1.11.3 with Gazebo classic
