Hi there!
I try to build firmware from a current master, but it fails.
Log is here:
Hope someone could say me, what should I do to fix it.
Thanks!
Hi there!
Log is here:
Thanks!
Try to install ninja
(or sometimes called ninja-build
and do make clean
and try again. I think I’ve seen similar issues without ninja.
My assumption is that this is something similar to this but I might be completely wrong.
Yes, it helps, thank you a lot!
I’m not sure that it’s the same problems, but I think it would be great if build system will check that ninja is installed before any builds.
