I am trying to connect to my PX4 SITL drone using DroneKit, but I run into a few problems.
When I try to connect on port 14540 I get an error that says:
Start simulator (SITL)
Connecting to vehicle on: udpin:127.0.0.1:14540
File "/Users/mikeyjoyce/Documents/Drone Delivery/scripts/test.py", line 40, in <module>
vehicle = connect(connection_string, wait_ready=False)
File "/usr/local/lib/python3.9/site-packages/dronekit-2.9.2-py3.9.egg/dronekit/__init__.py", line 3204, in connect
File "/usr/local/lib/python3.9/site-packages/dronekit-2.9.2-py3.9.egg/dronekit/mavlink.py", line 128, in __init__
File "/usr/local/lib/python3.9/site-packages/dronekit-2.9.2-py3.9.egg/dronekit/mavlink.py", line 54, in __init__
OSError: [Errno 48] Address already in use
If I try to connect on the other ports (14550, 14030, and 13280) it times out because it does not receive a heartbeat.
The other technologies I am using are:
Mac OS 12.4
Unreal 4.27
AirSim plugin for Unreal (this is my simulator)
This is the code I am running to try and establish a connection:
connection_string = 'udpin:127.0.0.1:14540'
print("Connecting to vehicle on: %s" % (connection_string,))
vehicle.wait_ready(True, raise_exception=False)
When I am running the SITL simulation I am also getting this error which may or may not be related to this problem:
px4 starting.
INFO [init] found model autostart file as SYS_AUTOSTART=10016
INFO [param] selected parameter default file eeprom/parameters_10016
INFO [parameters] BSON document size 233 bytes, decoded 233 bytes (INT32:10, FLOAT:2)
[param] Loaded: eeprom/parameters_10016
INFO [dataman] data manager file './dataman' size is 7866640 bytes
PX4 SIM HOST: localhost
INFO [simulator] Waiting for simulator to accept connection on TCP port 4560
INFO [simulator] Simulator connected on TCP port 4560.
INFO [commander] LED: open /dev/led0 failed (22)
PWM_AUX_OUT: curr: 0 -> new: 1234
PWM_MAIN_OUT: curr: 0 -> new: 1234
INFO [init] Mixer: etc/mixers/quad_w.main.mix on /dev/pwm_output0
INFO [init] setting PWM_AUX_OUT none
INFO [mavlink] mode: Normal, data rate: 4000000 B/s on udp port 18570 remote port 14550
INFO [mavlink] mode: Onboard, data rate: 4000 B/s on udp port 14280 remote port 14030
INFO [mavlink] mode: Gimbal, data rate: 400000 B/s on udp port 13030 remote port 13280
INFO [mavlink] MAVLink only on localhost (set param MAV_{i}_BROADCAST = 1 to enable network)
INFO [logger] [logger] ./log/2022-08-12/22_04_05.ulg
INFO [logger] Opened full log file: ./log/2022-08-12/22_04_05.ulg
pxh> ERROR [simulator] poll timeout 0, 60
