Hello! I am building a triple redundant algorithm for PX4. After studying a bit further the multi-ekf support, I’m changing my strategy about fault detection. Instead of reading the topic estimator_status.msg I climbed to the upper level to read the estimator_selector_status.msg and to make the decision using the “healthy” of each instance as well as “instances_available”, “instance_changed_count”, “gyro_fault_detected”, “accel_fault_detected” or even “combined_test_ratio” and “relative_teste_ratio”. Does anyone think it’s reasonable to consider a PX4 system failure if I have less than 3 healthy instances from multi-ekf? I am still trying to find the best way to relate this new data variables with my conclusion about PX4 status. Thanks in advance!
Related topics
| Topic | Replies | Views | Activity | |
| Triple redudant system | 5 | 1328 | March 3, 2025 | |
Multiple (3+) gps receivers on a pixracer
5 | 686 | February 26, 2020 | |
| Multi EKF disaster | 4 | 644 | November 22, 2024 | |
| Detecting sensor failiure in ekf | 2 | 47 | September 3, 2024 | |
| Estimator selection | 4 | 2671 | June 5, 2017 |
